查看: 3450|回复: 4
[求助] DC运行不起来 License问题
发表于 2021-2-22 16:02:45 | 显示全部楼层 |阅读模式
之前因为license过期的问题愁,现在已经解决了,大家可以借鉴这个,可以设置到2030年的,http://bbs.eetop.cn/thread-871122-1-1.html
现在出现了新的问题 如下:
09/06/2017 19:30:25 (snpslmd) ------------------------------------------------------------------
09/06/2017 19:30:25 (snpslmd) Checking the integrity of the license file...
09/06/2017 19:30:29 (snpslmd) Valid SSS feature found.
09/06/2017 19:30:29 (snpslmd) The feature is needed to enable the other keys in your license file.
09/06/2017 19:30:29 (snpslmd) Licensed to student@eetop
09/06/2017 19:30:29 (snpslmd) Siteid: 26356, Server Hostid: 000c298af342, Issued on: 1/8/2014
09/06/2017 19:30:29 (snpslmd) ------------------------------------------------------------------
19:30:40 (snpslmd) TCP_NODELAY NOT enabled
19:30:40 (snpslmd) OUT: "Design-Compiler" eda@localhost.localdomain  [l7f01007393_1]
19:44:15 (snpslmd) IN: "Design-Compiler" eda@localhost.localdomain  [l7f01007393_1]
20:31:05 (lmgrd) lmgrd will now shut down all the vendor daemons
运行design_vision出现的问题是:
Unable to obtain feature 'Design-Vision ' because:
Error: Can't communicate with the license server. (SEC-12)
Please contact  at root@, who is
your local Synopsys license administrator for Synopsys site 000.
有没有好心人帮忙解答一下,有偿有偿!
 楼主| 发表于 2021-2-22 16:05:29 | 显示全部楼层
顶一下
 楼主| 发表于 2021-2-23 16:28:59 | 显示全部楼层
解决啦,是.bashrc里面的问题
下面是改正过的:
alias lmli2='/opt/synopsys/scl/11.5/amd64/bin/lmgrd -c /opt/synopsys/license/license_f.dat -l~/syn_lic.log'
export SYNOPSYS=/opt/synopsys
export SNPSLMD_LICENSE_FILE=27000@localhost.localdomain
export SNPS_LICENSE_FILE=/opt/synopsys/license/license_f.dat
export PATH=$SYNOPSYS/syn2013.12/I-2013.12-SP4/binPATH
export PATH=$SYNOPSYS/scl/11.5/amd64/binPATH
alias dv=$SYNOPSYS/syn2013.12/I-2013.12-SP4/bin/design_vision
export DISPLAY=unix:0
 楼主| 发表于 2021-2-23 16:30:24 | 显示全部楼层
解决啦,是.bashrc设置的问题
下面是改过之后的:
 楼主| 发表于 2021-2-24 20:16:19 | 显示全部楼层
记录问题:DC内存不够,自动退出,然后再运行dc_shell进不去。
我的解决方法:
首先查看license有没有问题,syn_lic文件提示是port的问题;
我改了port号码,重新启动,license没有问题了,但是dc_shell还是不行;
然后我把port号码又改回原来的号码(27000),重新启动,license没有问题了,然后等了一会,dc_shell也可以打开了。
linux系统本来就是一个很魔幻的系统,大家遇到问题多一点耐心,可能真的不是你的问题,是运气问题。。。。。。
GMT+8, 2025-12-18 22:51 , Processed in 0.384840 second(s), 4 queries , Gzip On, Redis On.
