查看: 19662|回复: 46
Xilinx pci target设计参考
发表于 2003-9-5 15:20:19 | 显示全部楼层 |阅读模式
LBSALE[50]LBSALE[这个贴子最后由jackzhang在 2003/10/16 09:41pm 第 1 次编辑]
This source is distributed in the hope that it will be
useful, but WITHOUT ANY WARRANTY; without even the implied
warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
点击这里可看到:
http://www.eetop.cn/cgi-bin/topic.cgi?forum=18&topic=115
发表于 2003-9-6 00:35:45 | 显示全部楼层
快没钱了!
发表于 2003-9-7 19:04:03 | 显示全部楼层
好贵啊,但是好东西,还是要买的!
发表于 2003-9-7 19:22:57 | 显示全部楼层
问一个弱问题,为什么在MODELSIM里仿真不了??# Reading D:/Modeltech_xe/win32xoem/../tcl/vsim/pref.tcl
# do EEE.fdo
# Model Technology ModelSim XE vcom 5.5e_p1 Compiler 2001.11 Nov 16 2001
# -- Loading package standard
# ERROR: Could not open library xc7000 at xc7000: No such file or directory
# ERROR: PCI.vhd(4): Library xc7000 not found.
# -- Loading package std_logic_1164
# -- Loading package attributes
# -- Loading package std_logic_misc
# -- Loading package std_logic_arith
# -- Loading package std_logic_unsigned
# ERROR: Could not find D:/Modeltech_xe/win32xoem/../ieee.std_logic_components
# ERROR: PCI.vhd(9): cannot find expanded name: ieee.std_logic_components
# ERROR: PCI.vhd(9): Unknown field: std_logic_components.
# ERROR: PCI.vhd(10): Unknown identifier: xc7000
# ERROR: PCI.vhd(12): VHDL Compiler exiting
# ERROR: D:/Modeltech_xe/win32xoem/vcom failed.
# Error in macro ./EEE.fdo line 5
# D:/Modeltech_xe/win32xoem/vcom failed.
#     while executing
# "vcom -just e -93 -explicit  PCI.vhd"
Warning: A ModelSim starter license was detected and will be used, even though you have installed ModelSim XE. You should obtain an XE license in order to access ModelSim XE's full capabilities.
这是怎么回事?
 楼主| 发表于 2003-9-7 19:36:46 | 显示全部楼层
这个代码只是给你一个参考,不是我编写的,是以前我一个同事参加培训得到的。代码可能有bug,注意自己编写
发表于 2003-9-8 09:11:43 | 显示全部楼层
买了
发表于 2003-9-12 10:15:24 | 显示全部楼层
好心疼啊
发表于 2003-9-12 17:36:01 | 显示全部楼层
我买了,怎么什么也没有?
发表于 2003-9-20 20:12:13 | 显示全部楼层
没测试过还要买,这不简直就是坑人吗
发表于 2003-9-23 18:49:22 | 显示全部楼层
我也是
GMT+8, 2025-12-26 18:04 , Processed in 0.024567 second(s), 7 queries , Gzip On, Redis On.
