查看: 13370|回复: 25
[求助] AMS仿真 后仿遇到的问题 ncelab: Cannot find any unit under <目录名><器件名> :spectre in design library
发表于 2021-2-9 18:06:17 | 显示全部楼层 |阅读模式
进行后仿时,PEX输出Hspice,在config的view found中更改为pex的输出文件,然后进行ams仿真遇到报错。
----------报错分割线---------------
ncelab: *W,CUNOUN: Cannot find any unit under chrt018ull_hv30v.pmos_5p0:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'MP15' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP14' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP13' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP6' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP12' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP11' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP10' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP9' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP8' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP7' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP5' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP4' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP3' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP2' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP1' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MP0' of the unit 'pmos_5p0' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *W,CUNOUN: Cannot find any unit under chrt018ull_hv30v.nmos_5p0_dw:spectre in the design libraries.
ncelab: *E,CUCFUN: instance 'MN8' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN1' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN0' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN2' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN3' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN4' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN5' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
ncelab: *E,CUCFUN: instance 'MN6' of the unit 'nmos_5p0_dw' is unresolved in '\180NerveStimulator .DAC_PIN:schematic'.
Failed to elaborate ("180NerveStimulator" "DAC_spectre_test_postsimulation" "config").
论坛里的CIW->Conversion Tool Box->AMS simInfo from Spectre这个方法对我无效,希望论坛里的老师们能给出一些解决方案,谢谢
发表于 2021-2-9 18:53:15 | 显示全部楼层
要看一下你的switch view list里面有没有spectre view。如果没有的话,当然找不到模拟基本器件的binding了。
 楼主| 发表于 2021-2-9 19:34:38 | 显示全部楼层
amodaman 发表于 2021-2-9 18:53
要看一下你的switch view list里面有没有spectre view。如果没有的话,当然找不到模拟基本器件的binding了 ...
你好,请问switch view list是指我截图里的那个吗
发表于 2021-2-9 19:58:18 | 显示全部楼层
是的
 楼主| 发表于 2021-2-9 20:02:31 | 显示全部楼层
那我的view list里有spectre的情况下还是报错有可能是什么问题呢
发表于 2021-2-9 20:35:55 | 显示全部楼层
library list里面要添加你的PDK库,就是包含那些模拟器件的库。
 楼主| 发表于 2021-2-10 17:56:11 | 显示全部楼层
这个也是有的
发表于 2021-2-10 18:13:11 | 显示全部楼层
wxq0516 发表于 2021-2-10 17:56
这个也是有的
没有看到你的真正的switch view list是啥样的,不过如果symbol在switch view list里面是没有任何道理的。因为一旦发现symbol之后,netlister就中止遍历层次连接关系了,而symbol view里面并不包含simulator需要的信息。
发表于 2021-2-10 18:19:41 | 显示全部楼层
这个也是有的
而且要看一下chrt018ull_hv30这个器件到底有哪些views,调用时是怎么调用的,模型参数应该是什么?我没用过这个工艺所以猜不着。
 楼主| 发表于 2021-2-12 20:52:39 | 显示全部楼层
amodaman 发表于 2021-2-10 18:13
没有看到你的真正的switch view list是啥样的,不过如果symbol在switch view list里面是没有任何道理的 ...
switch view list就是我截图里那样,能否给我一些可能的解决方案呢,我可以一个个去试一试
GMT+8, 2025-12-25 11:00 , Processed in 0.025150 second(s), 4 queries , Gzip On, Redis On.
