楼主: Analog_2020
[求助] Cadence ADE仿真报错
发表于 2021-10-30 15:29:59 | 显示全部楼层
这个用最最最简单的awk脚本,几秒钟就处理出来了
发表于 2022-4-21 15:45:55 | 显示全部楼层
amodaman 发表于 2021-2-8 10:42
在ocean文件的simulator('spectre) 语句之前插入一句:
envSetVal("spectre.envOpts" "controlMode" 'str ...
您好,请教一下,如果在ADE L图形界面中直接点run的按钮出现楼主遇到的这种问题,该如何进行这一步绕过bug的操作?
发表于 2022-6-17 16:18:20 | 显示全部楼层
ldy777 发表于 2021-8-10 13:34
已解决 参考9楼大佬 谢谢
大哥,9楼不见了,请问这个问题是咋解决的啊
发表于 2022-6-17 16:32:55 | 显示全部楼层
已经解决,9楼大佬跑前排去了。谢谢大佬
发表于 2023-10-19 11:48:13 | 显示全部楼层
amodaman 发表于 2021-2-7 14:01
是不是在环境里面找不到spectre 可执行文件在哪里?试一下 which spectre的命令,看看系统返回什么。
如 ...
大佬,我现在就遇到了这个问题,输入 which spectre之后如下所示
/usr/bin/which: no spectre in (/etc/env:/home/disk/opt/mentor/calibre2018/aoi_cal_2018.1_27.18/bin:/home/disk/opt/synopsys/v11.10/linux64/bin:/home/disk/opt/synopsys/lc/lc/O-2018.06-SP1/bin:/home/disk/opt/synopsys/pt/pts/O-2018.06-SP1/bin:/home/disk/opt/synopsys/icc/icc/O-2018.06-SP1/bin:/home/disk/opt/synopsys/dc/syn/O-2018.06-SP1/bin:/home/disk/opt/synopsys/verdi/verdi/Verdi_O-2018.09-SP2/bin:/home/disk/opt/synopsys/verdi/verdi/Verdi_O-2018.09-SP2/platform/LINUX64/bin:/home/disk/opt/synopsys/vcs-mx/vcs-mx/O-2018.09-SP2/gui/dve/bin:/home/disk/opt/synopsys/vcs-mx/vcs-mx/O-2018.09-SP2/bin:/home/disk/opt/synopsys/startrc/starrc/O-2018.06-SP1/bin:/home/disk/opt/synopsys/Hspice-2015.06-3//hspice/bin:/home/disk/opt/synopsys/cscope64_2011.09.0.0.27_linux_x86/ai_bin:/home/disk/opt/synopsys/K-2015.06/bin:/home/disk/opt/synopsys/hsim2015/hsimplus/bin:/home/disk/opt/cadence/INNOVUS152/bin:/home/disk/opt/cadence/EDI142/bin:/home/disk/opt/cadence/GENUS152/bin:/home/disk/opt/cadence/INCISIVE151//tools/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/disk/opt/synopsys/fm/fm/O-2018.06-SP1/bin:/home/work/bin)
发表于 2024-12-10 18:22:25 | 显示全部楼层
感谢大佬!
GMT+8, 2025-10-1 15:27 , Processed in 0.013944 second(s), 3 queries , Gzip On, Redis On.
