查看: 2063|回复: 1
[求助] pt修tran
发表于 2021-2-3 17:16:29 | 显示全部楼层 |阅读模式
pt修drv只能用fix——eco——drc吗?修不动是不是没办法了,貌似没有add——buff——on——net
发表于 2021-2-3 21:59:34 | 显示全部楼层
insert_buffer_at_load_pins
Fix DRC violations with the fix_eco_drc command.
Fix setup violations with the fix_eco_timing -type setup command.
Fix hold violations with the fix_eco_timing -type hold command.
GMT+8, 2025-11-4 00:21 , Processed in 0.013990 second(s), 4 queries , Gzip On, Redis On.
