查看: 4924|回复: 5
[求助] Hspice网表仿真如何生成.sw0文件,想用.sw0文件与matlab交互
发表于 2021-1-23 13:43:51 | 显示全部楼层 |阅读模式
Hspice网表仿真如何生成.sw0文件,想用.sw0文件与matlab交互,为什么我只能生成.lis文件
求教
发表于 2021-1-23 19:25:06 | 显示全部楼层
Use an .OPTION POST statement to use AvanWaves to display high resolution
plots of simulation results on a graphics terminal or a high resolution laser
printer.
Use the .OPTION POST to provide output without specifying other
parameters. POST has defaults that supply most parameters with usable data.
an .OPTION POST statement to create a post-analysis file. The output file is in
proprietary binary format if POST = 0 or 1, or ASCII format if POST = 2
DC analysis results appear in output_file.sw#, which is produced as a result of
a .DC statement. This file contains the results of the applied stepped or swept DC
parameters defined in that statement. The results may include noise, distortion,
or network analysis.
发表于 2021-1-25 09:03:00 | 显示全部楼层
DC分析后 你的输出结果就是sw0文件,你要输出电压电流才有这个文件 你如果只仿真了但没输出结果 只有lis文件
发表于 2023-5-28 21:26:00 | 显示全部楼层
xuwenwei 发表于 2021-1-25 09:03
DC分析后 你的输出结果就是sw0文件,你要输出电压电流才有这个文件 你如果只仿真了但没输出结果 只有lis文 ...
您好,请问.sw0文件要怎么打开呢?
发表于 2023-5-29 08:34:17 | 显示全部楼层
xxfj 发表于 2023-5-28 21:26
您好,请问.sw0文件要怎么打开呢?
结果显示软件啊 waveview
发表于 2023-5-29 14:48:07 | 显示全部楼层
您好,请问.sw0文件要怎么打开呢?
用波形查看器打开就行了,比如waveview
GMT+8, 2025-10-3 01:56 , Processed in 0.014558 second(s), 4 queries , Gzip On, Redis On.
