查看: 3425|回复: 5
[求助] vco杂散问题
发表于 2020-12-19 21:32:34 | 显示全部楼层 |阅读模式
VCO是否有必要仿杂散?是通过输出频谱看吗?自己尝试放了下,结果如图,根据图片是否可以说杂散抑制为-49dB?(中心频率为6.4GHz,三次谐波处杂散最大)这种VCO的杂散性能算是正常的吗?希望大家指教一下,谢谢!!
发表于 2020-12-20 13:45:41 | 显示全部楼层
Hello, Third harmonic rejection of about 49dB is pretty good
but try to simulate the effect of having a very small (100mV peak-to-peakm 50MHz) sinewave imposed on the VDD supply.
Do this simulation and see its effect on your output spectrum
 楼主| 发表于 2020-12-22 10:36:31 | 显示全部楼层
but try to simulate the effect of hav ...
thank you! Very good advice.
发表于 2020-12-22 13:16:26 | 显示全部楼层
你那个叫harmonic,不叫杂散吧
发表于 2020-12-23 14:26:24 | 显示全部楼层
路过学习,很实用,谢谢分享。
 楼主| 发表于 2020-12-23 23:13:42 | 显示全部楼层
a104842708 发表于 2020-12-22 13:16
你那个叫harmonic,不叫杂散吧
VCO的杂散抑制定义不是载波和最大谐波的差值吗?对这些称呼确实不是很明确,麻烦指教,谢谢!
GMT+8, 2025-12-18 15:41 , Processed in 0.018769 second(s), 4 queries , Gzip On, Redis On.
