查看: 4940|回复: 12
[资料] 2020-The Fourth Terminal-Benefits of Body-Biasing Techniques for FDSOI Circuits and Systems
发表于 2020-12-4 17:28:11 | 显示全部楼层 |阅读模式
The CMOS integration race has reached limitations for planar silicon process
starting from the 40 nm node. The transistor channel was more and more difficult to
control and specific process integration methods such as pocket implant, silicon
strain, and lightly doped drain were introduced to enable devices’ good carrier
mobility and electrostatic control, are moreover this type of process integration
could not be successfully continued after the 20nm node. Starting from the 28nm
node a consensus solution emerged consisting in the use of fully depleted active
devices either fully depleted silicon on insulator (FD-SOI) or Fin-FET. While the
fundamental physics laws are similar for these two big families of devices, the
process integration is much different and had to bring the process engineers from
the well-known planar technologies (applies also for FD-SOI) to fully 3D structures
(for Fin-FET).
2020_The Fourth Terminal.pdf
24.05 MB, 下载次数: 146 , 下载积分: 资产 -8 信元, 下载支出 8 信元
发表于 2020-12-4 17:58:06 | 显示全部楼层
谢谢分享
发表于 2020-12-4 19:51:16 | 显示全部楼层
3q3q~~
发表于 2020-12-5 08:31:51 | 显示全部楼层
thanks
发表于 2020-12-5 08:52:36 | 显示全部楼层
感谢
发表于 2020-12-5 13:18:44 | 显示全部楼层
Thank you for sharing
发表于 2020-12-5 20:38:40 | 显示全部楼层
资料不错,多谢分享
发表于 2020-12-9 23:35:00 | 显示全部楼层
thanks
发表于 2020-12-10 01:16:39 | 显示全部楼层
Thanks for sharing, great technology especially for programmable current sources
发表于 2020-12-10 11:52:03 | 显示全部楼层
Thanks!!!
GMT+8, 2025-12-15 03:18 , Processed in 0.023224 second(s), 5 queries , Gzip On, Redis On.
