楼主: Jiliang
[求助] virtuoso ic618 CDB to OA
发表于 2022-5-16 10:56:05 | 显示全部楼层
good answer form #4
发表于 2022-6-30 19:43:03 | 显示全部楼层
fhchen2002 发表于 2020-12-4 10:32
Use "cdb2oa" to conduct the conversion offline.
In a Linux terminal, issue the following command (t ...
cdb2oa -h以后报下列错误,感觉IC618已经去掉cdb2oa了
ERROR (CDBOA-2003):Support for the CDB to OpenAccess translator has been removed. Contact Cadence Customer Support to discuss how to complete any outstanding migration tasks.
发表于 2023-6-3 16:26:00 | 显示全部楼层
Jiliang 发表于 2020-12-9 20:59
遇到这个错误。我待转CDB格式的Library是用的cmos65的工艺,但是转成OA后需要用tsmc65n的工艺。这个怎么 ...
我也是,请问解决了吗
发表于 2023-8-24 13:23:40 | 显示全部楼层
dsafda
发表于 2024-1-25 16:17:44 | 显示全部楼层
EnjoyQ 发表于 2022-3-30 10:22
我这运行显示这样,怎么解决,用旧版换不太切合实际
问问解决了吗,我也显示这样
发表于 2024-1-25 21:48:47 | 显示全部楼层
最新版的IC618把命令都移除了
发表于 2024-3-16 14:42:24 | 显示全部楼层
ERROR (CDBOA-2003):Support for the CDB to Ope ...
也是遇到同一样的情况, 有办法解决吗?
发表于 2024-12-8 22:14:09 | 显示全部楼层
cdb2oa -lib <t_libName> -cdslibpath <t_libPath>
<t_libName> : process name
<t_libPath> : process directory
terminal directory should be another directory
发表于 2025-3-18 11:04:31 | 显示全部楼层
一样的
> cdb2oa -h
GMT+8, 2025-9-14 05:19 , Processed in 0.015266 second(s), 3 queries , Gzip On, Redis On.
