查看: 34155|回复: 50
Spectre仿真报错,Internal error found in spectre during AHDL read-in
发表于 2020-11-3 15:19:43 | 显示全部楼层 |阅读模式
求助各位大神,我用的是Spectre18.1,无法正常仿真,报错好像是AHDL无法正确读取。切换成Spectre19.1也是同样的问题出现。
论坛上面的三种方法都试了一下,但还是有问题。已尝试的如下:
1.已在.bashrc中添加 export CDS_AHDLCMI_ENABLE=YES
2.已在.bashrc中添加 export CDS_AUTO_64BIT=ALL
3.在spectre的setup-Environment中勾选run with 64-bit binary,并且在user command-line options中输入-64
但是都没用,还是报同样的问题。求助一下各位大神,这个应该怎么解决?
哦另外,,更改后我只是重新输入了bashrc和重开了virtuoso,还需要重启硬件设备吗?
多谢各位大佬!
 楼主| 发表于 2020-11-3 15:20:40 | 显示全部楼层
完整报错:
Internal error found in spectre during AHDL read-in, in `esdpsh_va', during circuit read-in, during hierarchy flattening,.
    FATAL (SPECTRE-18): Segmentation fault.Encountered a critical error during simulation. Run `mmsimpack' (see mmsimpack -h for detailed usage information) to package the netlist and log files as a compressed tar file. Then, contact your Cadence representative or submit a service request via Cadence Online Support, including the tar file and any other information that could help identify the problem.Encountered a critical error during simulation. Run `mmsimpack' (see mmsimpack -h for detailed usage information) to package the netlist and log files as a compressed tar file. Then, contact your Cadence representative or submit a service request via Cadence Online Support, including the tar file and any other information that could help identify the problem.
发表于 2020-11-3 15:30:40 | 显示全部楼层
7.6的系统?
 楼主| 发表于 2020-11-3 16:19:24 | 显示全部楼层
Yes, RHEL 7.6
发表于 2020-11-3 16:22:17 | 显示全部楼层
恭喜你,已找到问题所在。
 楼主| 发表于 2020-11-3 16:26:33 | 显示全部楼层
joycechou1110 发表于 2020-11-3 16:22
恭喜你,已找到问题所在。
额?是这个系统不支持spectre18.1和19.1吗?还是说我需要安装什么插件呢?
要是是不支持的话,那我需要安装版本更低一些的spectre吗?
感谢大神帮忙~
回复 支持 0 反对 1
 楼主| 发表于 2020-11-3 16:44:25 | 显示全部楼层
恭喜你,已找到问题所在。
另外我有点疑惑,我看论坛上面有7.6的系统,安装spectre 18.1的说明呀,这个应该是能用的吧?
但是我连接到spectre18.1版本也是报这个问题 。。
请大神再帮忙指点一下,多谢
 楼主| 发表于 2020-11-4 09:43:57 | 显示全部楼层
问题已经解决了,大概就是之前说的那三种情况中的一种?只是没有重启服务器,可能没有应用。重启了就好了
果然遇事不决就重启!
回复 支持 2 反对 0
发表于 2021-2-23 10:02:40 | 显示全部楼层
大佬,我现在也是radhat7.6   部分可以仿真。部门报错
发表于 2021-3-19 10:40:01 | 显示全部楼层
强大的eetop,我新服务器也是遇到这个问题,现在也根据楼主说的解决了,灰常感谢!!!!
回复 支持 0 反对 1
GMT+8, 2025-12-12 04:40 , Processed in 0.018839 second(s), 4 queries , Gzip On, Redis On.
