查看: 11600|回复: 21
免安装免破解免费的vcs2016 + verdi2016的docker镜像
发表于 2020-9-29 02:35:18 | 显示全部楼层 |阅读模式
免费的synopsys全套包括dc2016 icc2016 pt2015 fm2016 lc2016的docker镜像
http://bbs.eetop.cn/forum.php?mo ... 833&fromuid=1762666
发表于 2020-9-29 10:43:18 | 显示全部楼层
楼主好人,下载链接在哪里?
发表于 2020-10-1 06:18:25 | 显示全部楼层
感謝樓主,不過沒看到下載連結
 楼主| 发表于 2020-10-1 09:39:25 | 显示全部楼层
jason3380 发表于 2020-10-1 06:18
感謝樓主,不過沒看到下載連結
docker pull
 楼主| 发表于 2020-10-1 09:40:49 | 显示全部楼层
flyket 发表于 2020-9-29 10:43
楼主好人,下载链接在哪里?
docker pull
发表于 2020-10-3 11:42:37 | 显示全部楼层
thanks!
发表于 2020-11-8 09:59:47 | 显示全部楼层
楼主你好,我尝试在wsl2的docker上安装,但是遇到了这个问题
9:57:51 (lmgrd) Starting vendor daemons ...
9:57:51 (lmgrd) Started snpslmd (internet tcp_port 60507 pid 875)
9:57:51 (snpslmd) FlexNet Licensing version v11.12.1.2 build 152538 x64_lsb
9:57:52 (snpslmd) Cannot open daemon lock file
9:57:52 (snpslmd) EXITING DUE TO SIGNAL 41 Exit reason 9
9:57:52 (lmgrd) snpslmd exited with status 41 (Exited because another server was running)
9:57:52 (lmgrd) MULTIPLE "snpslmd" license server systems running.
9:57:52 (lmgrd) Please kill, and run lmreread
9:57:52 (lmgrd)
9:57:52 (lmgrd) This error probably results from either:
9:57:52 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
9:57:52 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
9:57:52 (lmgrd)       (which would leave the vendor daemon running).
9:57:52 (lmgrd) To correct this, do a "ps -ax | grep snpslmd"
9:57:52 (lmgrd)   (or equivalent "ps" command)
9:57:52 (lmgrd) and kill the "snpslmd" process.
你有遇到吗或者你知道怎么解决吗
发表于 2020-12-18 19:54:32 | 显示全部楼层
楼主 链接失效了
发表于 2020-12-24 21:21:34 | 显示全部楼层
9:57:51 (lmgrd) Starting vendor daemons .. ...
我也遇到这个问题了
看起来在docker中的网卡没有ifcfg-eth0
发表于 2020-12-25 21:32:51 | 显示全部楼层
我把SCL_11_11改成SCL_10_9后,lmgrd可以正常执行了.看起来,docker中只能用比较老的SCL.
GMT+8, 2025-12-21 15:12 , Processed in 0.019143 second(s), 6 queries , Gzip On, Redis On.
