查看: 21207|回复: 27
[求助] lvs missing port求助一下大家
发表于 2020-5-15 22:20:33 | 显示全部楼层 |阅读模式
报了这样的错,拜托各位神通广大的大佬
CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of ports (see below).
  Error:    Connectivity errors.
LAYOUT CELL NAME:         opa_test2_cell
SOURCE CELL NAME:         opa_test2_cell
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              0        10    *
Nets:              11        11
Instances:         15         5    *    MN (4 pins)
                    12         6    *    MP (4 pins)
Total Inst:        27        11
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              0        10    *
Nets:              11        11
Instances:          5         5         MN (4 pins)
                     6         6         MP (4 pins)
Total Inst:        11        11
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net 6                                                     VBP
           11
       --- 2 Connections On This Net ---                         --- 3 Connections On This Net ---
       M7(2.652,17.842):g                                        ** unmatched connection **
       M18(21.501,17.862):g                                      ** unmatched connection **
       ** unmatched connection **                                MM1:g
       ** unmatched connection **                                MM4:g
  2    Net 8                                                     ** no similar net **
  3    Net 3                                                     ** no similar net **
  4    Net 2                                                     ** no similar net **
  5    Net 1                                                     ** no similar net **
  6    Net 9                                                     ** no similar net **
  7    Net 4                                                     ** no similar net **
  8    Net 7                                                     ** no similar net **
  9    Net 10                                                    ** no similar net **
10    ** no similar net **                                      VDD
11    ** no similar net **                                      GND
12    ** no similar net **                                      VBN
13    ** no similar net **                                      VIN+
14    ** no similar net **                                      VIN-
15    ** no similar net **                                      VIN2+
16    ** no similar net **                                      VIN2-
17    ** no similar net **                                      VOUT+
18    ** no similar net **                                      VOUT-
                                   INCORRECT PORTS
19    ** missing port **                                        VDD on net: VDD
20    ** missing port **                                        GND on net: GND
21    ** missing port **                                        VIN+ on net: VIN+
22    ** missing port **                                        VIN- on net: VIN-
23    ** missing port **                                        VIN2+ on net: VIN2+
24    ** missing port **                                        VIN2- on net: VIN2-
25    ** missing port **                                        VBP on net: VBP
26    ** missing port **                                        VBN on net: VBN
27    ** missing port **                                        VOUT+ on net: VOUT+
28    ** missing port **                                        VOUT- on net: VOUT-
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               0          0            0           10
   Nets:                3          2            8            9
   Instances:           0          0            5            5    MN(N)
                        0          0            6            6    MP(P)
   Total Inst:          0          0           11           11
o Statistics:
   23 layout mos transistors were reduced to 7.
     16 mos transistors were deleted by parallel reduction.
                                  UNMATCHED OBJECTS
       LAYOUT                                                    SOURCE
       M13(13.590,12.860)  MP(P)                                 ** unmatched instance **
       M15(17.165,12.860)  MP(P)                                 ** unmatched instance **
       M18(21.501,17.862)  MP(P)                                 ** unmatched instance **
       M7(2.652,17.842)  MP(P)                                   ** unmatched instance **
       M8(4.660,12.860)  MP(P)                                   ** unmatched instance **
       M11(9.130,12.860)  MP(P)                                  ** unmatched instance **
       M0(9.395,3.160)  MN(N)                                    ** unmatched instance **
       X19/M0(6.045,3.160)  MN(N)                                ** unmatched instance **
       X20/M0(17.945,3.060)  MN(N)                               ** unmatched instance **
       X21/M0(10.288,8.804)  MN(N)                               ** unmatched instance **
       X22/M0(13.853,8.777)  MN(N)                               ** unmatched instance **
       ** unmatched instance **                                  MM4  MP(P)
       ** unmatched instance **                                  MM3  MP(P)
       ** unmatched instance **                                  MM0  MP(P)
       ** unmatched instance **                                  MM5  MP(P)
       ** unmatched instance **                                  MM2  MP(P)
       ** unmatched instance **                                  MM1  MP(P)
       ** unmatched instance **                                  MM10  MN(N)
       ** unmatched instance **                                  MM9  MN(N)
       ** unmatched instance **                                  MM8  MN(N)
       ** unmatched instance **                                  MM7  MN(N)
       ** unmatched instance **                                  MM6  MN(N)
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
发表于 2020-5-16 08:58:53 | 显示全部楼层
打没打label,首先确定这个
发表于 2020-5-16 13:36:19 | 显示全部楼层
看你的layout里的port一个都没识别出来。
给你列几个最可能的原因:
1、layout里没打label
2、layout里的label用成了drw属性的,一般的工艺应该用对应金属的pin属性的
点评
找到原因了,pin的那层layer应该和metal1完全覆盖,不然会报错unattached label,所以会missing port  发表于 2024-5-18 22:18
我的pin是有的,而且不管是drw还是pin都会报这个错误,请教一下有可能是什么原因?  发表于 2024-5-18 21:20
回复 支持 5 反对 0
 楼主| 发表于 2020-5-20 11:50:35 | 显示全部楼层
给你列几个最可能的原因:
1、layout里没打label
image.png 我点击的是create label打的标签,把原来是drw换成了metal1 pin。还是不行呢,不知道什么原因,大佬指教
 楼主| 发表于 2020-5-20 11:51:29 | 显示全部楼层
VAEEE 发表于 2020-5-16 08:58
打没打label,首先确定这个
我发了图,您看一下,我是create label添加标签的
发表于 2020-5-24 15:41:44 | 显示全部楼层
速速速速速 发表于 2020-5-20 11:50
我点击的是create label打的标签,把原来是drw换成了metal1 pin。还是不行呢,不知道什么原因,大佬指教: ...
你把drw换成pin后,错误数量没有变化吗
 楼主| 发表于 2020-5-25 20:06:10 | 显示全部楼层
是的啊,还有没有可能是其他原因呢
发表于 2020-5-25 20:42:02 | 显示全部楼层
速速速速速 发表于 2020-5-25 20:06
是的啊,还有没有可能是其他原因呢
没有实际看到,很难说是什么问题。
你私信我吧,我远程帮你看一下
发表于 2020-5-29 09:51:51 | 显示全部楼层
你把schematic里的pin name都大写试试
发表于 2020-5-29 20:23:00 | 显示全部楼层
这个和工艺有关,有的工艺是需要把label写成对应金属的cad层,有的是直接写成drw层就可以了
GMT+8, 2025-12-29 20:43 , Processed in 0.021035 second(s), 5 queries , Gzip On, Redis On.
