查看: 2372|回复: 1
[求助] latching clock path 与 capture clock path的区别和联系
发表于 2020-5-4 22:15:57 | 显示全部楼层 |阅读模式
新人菜鸟问个问题,还请前辈们不吝赐教:latching clock path 与 capture clock path的区别和联系
原文是:BCWC for hold checks makes the latching clock path 10 percent slower. This shifts the clock edge closer to the data edge, revealing a hold failure.
set_timing_derate -min -early 1.0 -late 1.1
发表于 2020-5-5 09:30:18 | 显示全部楼层
时钟路径跟data 路经
GMT+8, 2025-12-29 06:27 , Processed in 0.012576 second(s), 4 queries , Gzip On, Redis On.
