楼主: ileom
[资料] innovus15.2license
发表于 2022-3-28 16:22:34 | 显示全部楼层
谢谢!!!
发表于 2022-5-6 09:24:33 | 显示全部楼层
thanks!!!!
发表于 2022-5-9 09:45:32 | 显示全部楼层
我这边没法用,可能我这边有问题吧
发表于 2022-5-9 09:57:04 | 显示全部楼层
可以了,厉害厉害。
发表于 2022-5-16 15:45:11 | 显示全部楼层
我这边没法用...
./IC618-500-8/tools.lnx86/bin/64bit/lmgrd -c ./license.dat -l ./license.log
15:36:19 (cdslmd) Invalid license key (inconsistent authentication code)
15:36:19 (cdslmd)       ==>FEATURE 111 cdslmd 2100.000 permanent uncounted HOSTID=ANY \
        SIGN2="01E8 39FE 0236 8578 B047 5A43 D292 BA19 092F 6940 FF05 \
        34E0 503D 8D5B 960E 019C 0672 DE74 DD70 068D E5A2 93EE AB05 \
        8C85 DEEF 3939 07CC 34DF 937F EEAD"
15:36:19 (cdslmd)       ==>FEATURE Voltus_Power_Integrity_XL cdslmd 2100.000 permanent uncounted \
        HOSTID=ANY SIGN2="0E64 D009 0D5E A448 E1B4 B007 DEF1 A159 00CA \
        34CD A55B 0D0C F511 AFAA 1C8B 0749 610B 3FCC 3879 7273 6B5D \
        F628 4947 1D40 AD4E EA39 D85F BCEC A803 73D0"
15:36:19 (cdslmd) License server system started on slave
15:36:19 (cdslmd) No features to serve, exiting
15:36:19 (cdslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
15:36:19 (lmgrd) cdslmd exited with status 36 (No features to serve)
15:36:19 (lmgrd) cdslmd daemon found no features.  Please correct
15:36:19 (lmgrd) license file and re-start daemons.
15:36:19 (lmgrd)
15:36:19 (lmgrd) This may be due to the fact that you are using
15:36:19 (lmgrd) a different license file from the one you expect.
15:36:19 (lmgrd) Check to make sure that:
15:36:19 (lmgrd) ./license.dat
15:36:19 (lmgrd) is the license file you want to use.
15:36:19 (lmgrd)
15:36:53 (lmgrd) lmgrd will now shut down all the vendor daemons
发表于 2022-7-19 12:16:55 | 显示全部楼层
非常好用,刚用上了
发表于 2022-8-3 09:54:45 | 显示全部楼层
不知道18.10版本的能用不,求解
发表于 2022-8-3 10:17:00 | 显示全部楼层
这个license里面压根没有innovus的license,拉跨
发表于 2022-8-28 21:25:37 | 显示全部楼层
thanks
发表于 2022-9-6 16:12:56 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-30 08:03 , Processed in 0.020026 second(s), 3 queries , Gzip On, Redis On.
