查看: 3601|回复: 2
[求助] Spyglass skip_platform_check
发表于 2019-12-6 23:18:27 | 显示全部楼层 |阅读模式
######################### STARTING SPYGLASS #######################
SpyGlass Predictive Analyzer(R) - Version SpyGlass_vN-2017.12-1
Last compiled on Jan 21 2018
All Rights Reserved. Use, disclosure or duplication
without prior written permission of Synopsys Inc. is prohibited.
Technical support: email spyglass_support@synopsys.com.
INFO [SPG#1044]: Running in batch mode...
SpyGlass is supported only on 64-bit machines of Red Hat (Enterprise Linux release 6.6|6.7|6.8|7.1|7.2|7.3) Suse (version 11|12) flavors
Detected OS flavor is not a supported OS flavor.
SpyGlass run may have OS related issues specific to this distribution.
Please contact Synopsys Support for any further queries in this regard.
Please set SKIP_PLATFORM_CHECK variable to disable this platform check
######################### ENDING SPYGLASS #########################
如上  可以设置SKIP_PLATFORM_CHECK 。但是不知道怎么设置。不知道在哪设置。求大佬提醒
发表于 2019-12-7 19:58:47 | 显示全部楼层
环境变量里面
发表于 2020-5-19 16:35:03 | 显示全部楼层
csh or tcsh : setenv SKIP_PLATFORM_CHECK 1
GMT+8, 2025-12-25 13:58 , Processed in 0.013461 second(s), 3 queries , Gzip On, Redis On.
