lab data: ces_lpf_hld_2013.06
由于没有lab guide, 做的一头雾水。
lab2 lab3做完后, 发现有level shift 没有被插入的问题。
I_ADD/a_ret, 这个是retention save/restore的module 输入端口,顶层产生,电源VDD
I_ADD这个instance内部有power switch, VDD1 -> VDD1_ADD
日志中有info.
Information: Level shifter LSDNX8_HVT from library saed90nm_max_hthn_hvt_lsh cannot be inserted to net I_ADD/a_ret because of main power mismatch(require power pin VDDL to be connected to domain primary power VDD1_ADD). (MV-753)
做完后 check_mv_design -verbose, 出现缺失level_shift的warning
Warning: Found 1 pin to pin connections requiring level shifter(s). (MV-229)
Warning: Pin 'I_PWR_CTRL/sr_ctrl_reg/Q'(VDD[1.08v]) cannot drive 'I_ADD/U26/INP'(VDD1[0.70v]) due to voltage differences (effective strategy is [rule = both, threshold = 0.00]). (MV-231)
这个lab没有读入sdc, 是不是没有定义时钟导致retention的save/restore信号没有被插入level_shift?
谢谢各位大神回复。
