查看: 4641|回复: 1
关于Diva的验证规则
发表于 2007-11-23 10:02:24 | 显示全部楼层 |阅读模式
验证规则里有这样的语句:
checkPullUp( )
checkPullDown( )
/* Checks all nets for a path from the net through devices to nets
identified as power nets. Then checks all nets for a path from
the net through devices to nets identified as ground nets. */
两个语句的解释相同的,那两者究竟有什么区别?这两句话有什么用,是防止什么情况发生呢?
发表于 2008-3-16 22:40:35 | 显示全部楼层
从名字就可以看出,一个是检测到电源(或正电源)的通路,另一个是检测到地(或负电源)的通路。
GMT+8, 2025-12-6 10:28 , Processed in 0.011315 second(s), 5 queries , Gzip On, Redis On.
