查看: 1727|回复: 2
[求助] 开发ARM单片机需要用FPGA来验证吗?
发表于 2019-7-11 15:27:55 | 显示全部楼层 |阅读模式
cortexm0  IP core is free.but only VCS+verdi  is enough to develop a MCU?
发表于 2019-7-11 16:12:27 | 显示全部楼层
如果你的最终目标是基于cortexm0的MCU芯片,那么vcs+verdi远远不够。
你需要linux、putty、vnc、office、VCS、verdi、DC、TetraMax、PT、ICC、Formality、Calibre、Tessent、Keil、Protel等等
你可能还需要电烙铁、电阻、电容。。。。
发表于 2019-7-13 00:25:14 | 显示全部楼层
this is depend on your verification level .
if you only want verification at RTL simulation level.  these tool is enough
If you want verification the real chip and real app , this is not enough
GMT+8, 2025-11-25 05:45 , Processed in 0.011780 second(s), 3 queries , Gzip On, Redis On.
