楼主: yexy515
[求助] IC617 AMS仿真遇到问题
 楼主| 发表于 2019-7-17 16:49:08 | 显示全部楼层
在tools的同一级目录,点右键打开term,照下面的运行:
1After installing the Virtuoso AMS Designer software, the system manager may
pre-compile the included libraries, such as sample, by running the utility
amsLibCompile from the IC5.X.XX install directory.
这个编译完,ahdl那些库才能在AMS中仿真,term里运行amsLibCopile就行
 2The system manager may also pre-compile the included Connect Modules library
by running the utility /tools/affirma_ams/etc/install/amsConnectLibCompile
from the IUSXX install directory.
这个是编译connectLib那个库的,term里运行amsConnectLibCompile就行,然后include的进去
 楼主| 发表于 2019-7-17 16:51:01 | 显示全部楼层
ywic 发表于 2019-7-17 16:14
请问编译的具体方法能提供一下么?我去IUS安装路径编译貌似没用!
发表于 2020-2-26 13:41:51 | 显示全部楼层
楼主您好,我按照您的指示运行了两个命令,然后再including ConnectLib库,但是每次点击Connect Rules时总是弹出那个该死的框框[Connect rules are not found in your AMS installation]。楼主有什么好的解决办法?
发表于 2022-5-31 10:33:04 | 显示全部楼层
楼主,运行amsLibCopile命令是啥啊?amsLibCopile是再IC617目录下运行,对么?运行amsConnectLibCompile命令是啥啊?amsConnectLibCompile是再INCISIVE151目录下运行,对么?
发表于 2022-5-31 11:04:32 | 显示全部楼层
楼主,我打开的config界面和ADE L 界面跟你的不一样,能帮忙看一下是哪里出问题了么 微信图片_20220531110104.jpg 微信图片_20220531110111.jpg
发表于 2022-5-31 11:18:11 | 显示全部楼层
yexy515 发表于 2019-7-5 09:34
就算是设置了rules,还是报错
大神,能帮忙看一下么?我的config界面菜单栏缺少AMS,在ADE L -> simulation -> netlist and run options,这一界面缺少connet rules,能帮忙看一下哪里出问题了么? 微信图片_20220531110104.jpg 微信图片_20220531110111.jpg 092621f7lcy1mlmlm4kmkl.bmp 093405vsn3oyi0qwxuxpuz.bmp
发表于 2023-12-18 09:22:01 | 显示全部楼层
cq20 发表于 2022-5-31 11:18
大神,能帮忙看一下么?我的config界面菜单栏缺少AMS,在ADE L -> simulation -> netlist and run option ...
您好请问解决了吗,我也是这个问题
GMT+8, 2025-12-27 03:39 , Processed in 0.019864 second(s), 4 queries , Gzip On, Redis On.
