查看: 6987|回复: 8
[求助] Liberate使用问题
发表于 2019-5-22 10:34:18 | 显示全部楼层 |阅读模式
在用Liberate对标准单元提取时序等信息时,出现了下面的错误提示,不知道大家又没见过。之前都没有出现过,寻求各位的帮助!
  1. LIBERATE - SYSTEM ERROR - could not execute command: cd /tmp/altos.VLSI-01.T20190522103545663742S0071995.0; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre  +lqt 0 =log sim.lis  +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D07A87CC546A21AD943E035B959920DD879D11B8977A237E979D11B8977A237E92535AE49C2626B0D00003AB1 /tmp/altos.VLSI-01.T20190522103545663742S0071995.0/sim.sp >& /dev/null
  2. *Info* Simulation failed to complete. Restart the simulation in 5 seconds on host VLSI-01.
  3. *Info* Run Spectre : (0) at /tmp/altos.VLSI-01.T20190522103545663742S0071995.0
  4. *Error* (char_library) Failed to run 'cd /tmp/altos.VLSI-01.T20190522103545663742S0071995.0; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre  +lqt 0 =log sim.lis  +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D07A87CC546A21AD943E035B959920DD879D11B8977A237E979D11B8977A237E92535AE47C26C6B0D00003AC0 /tmp/altos.VLSI-01.T20190522103545663742S0071995.0/sim.sp >& /dev/null' on host VLSI-01.
  5.       * Spectre exit code : 2(stop simulation because of Spectre error condition)
  6. LIBERATE - SYSTEM ERROR - could not execute command: cd /tmp/altos.VLSI-01.T20190522103545663742S0071995.0; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre  +lqt 0 =log sim.lis  +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D07A87CC546A21AD943E035B959920DD879D11B8977A237E979D11B8977A237E92535AE5EC2756B0D00003AC2 /tmp/altos.VLSI-01.T20190522103545663742S0071995.0/sim.sp >& /dev/null
  7. *Info* Simulation failed to complete. Restart the simulation in 5 seconds on host VLSI-01.
  8. *Info* Run Spectre : (0) at /tmp/altos.VLSI-01.T20190522103545663742S0071995.0
  9. *Error* (char_library) Failed to run 'cd /tmp/altos.VLSI-01.T20190522103545663742S0071995.0; /eda/cadence/2016-17/RHELx86/MMSIM_15.10.627/bin/spectre  +lqt 0 =log sim.lis  +libtkn 000170DF5EB91CC41D8B41DB50E14DEB4DDB67C73FE609F74FDE73A937D417C30CC06C8A58BA47F509CF5BBA17DE078370B328E937DE22D2589906C00DB146E80A82779C24F925A20AD079D119DF75F437E965CB78E177A24E9D07A87CC546A21AD943E035B959920DD879D11B8977A237E979D11B8977A237E92535AE6CC2476B0D00003AC0 /tmp/altos.VLSI-01.T20190522103545663742S0071995.0/sim.sp >& /dev/null' on host VLSI-01.
  10.       * Spectre exit code : 2(stop simulation because of Spectre error condition)
    复制代码
发表于 2019-5-24 14:16:08 | 显示全部楼层
看着像是工具的环境变量问题
 楼主| 发表于 2019-5-25 10:00:04 | 显示全部楼层
yanhong_ic 发表于 2019-5-24 14:16
看着像是工具的环境变量问题
但是换成另外一个工艺,就没有问题了。难道是有些设置不适合在另一个工艺下,我再检查检查吧
发表于 2019-6-5 13:39:00 | 显示全部楼层
仿真仿不了,很有可能是工艺的问题啊
发表于 2019-6-13 16:51:16 | 显示全部楼层
一般来说这是随机错误,重跑就能过了。可是你用同样的设置还能重现的话,那就是工具版本或者设计的问题了。
 楼主| 发表于 2019-6-14 10:48:55 | 显示全部楼层
落水清风 发表于 2019-6-13 16:51
一般来说这是随机错误,重跑就能过了。可是你用同样的设置还能重现的话,那就是工具版本或者设计的问题了。 ...
因为设置了一个不属于这个工艺可用的变量。define_leafcell,这个没用对。
发表于 2022-3-9 16:19:04 | 显示全部楼层
你好,我也遇到了这样的问题,请问最后是怎么解决的呢
发表于 2022-8-21 10:17:00 | 显示全部楼层
你好,请问如何找工艺库的可用变量呢?
发表于 2025-5-9 17:39:05 | 显示全部楼层
请问有人解决这个问题了吗?
GMT+8, 2025-12-29 04:32 , Processed in 0.018225 second(s), 5 queries , Gzip On, Redis On.
