查看: 1836|回复: 3
[求助] how to extract testpoint from the only source——SPEC
发表于 2019-4-2 17:55:09 | 显示全部楼层 |阅读模式
when reading the SPEC, it is ok, but when it comes to extract testpoint from it, I just don't know how to put it and how to do it.
发表于 2019-4-3 14:20:35 | 显示全部楼层
先划分规格大类,比如功能、场景、性能、结构、异常、上下游配合等,然后再细分,时序、速率、控制、告警,低功耗,维测等,再看看有没有几个特性耦合的。当然了,也要看SPEC是否规范,正规协议或者器件的规范,都会有规格、应用场景、性能等部分,你就根据这里面自己从大到小去提取。
发表于 2019-4-8 11:51:37 | 显示全部楼层
gaurson 发表于 2019-4-3 14:20
先划分规格大类,比如功能、场景、性能、结构、异常、上下游配合等,然后再细分,时序、速率、控制、告警, ...
相当到位了
 楼主| 发表于 2019-4-12 16:38:17 | 显示全部楼层
thank you soooooooooooooo much
GMT+8, 2025-12-20 04:12 , Processed in 0.017333 second(s), 4 queries , Gzip On, Redis On.
