楼主: tStone
[讨论] LDNMOS的gate和source同时接到高电位用来做pn结是否可行?
发表于 2019-3-23 11:45:03 | 显示全部楼层
Your VCC connects to P-Body, and Drain connect to a voltage which lower than VCC,
This P/N diode is forward biased if the voltage difference is higher than 0.7v.
 楼主| 发表于 2019-3-25 08:51:38 | 显示全部楼层
This P/N diode is  ...
这正是我担心的地方。
GMT+8, 2025-12-22 17:52 , Processed in 1.035611 second(s), 3 queries , Gzip On, Redis On.
