查看: 1976|回复: 0
[求助] dft pattern
发表于 2019-1-8 09:21:25 | 显示全部楼层 |阅读模式
请教一个问题,灌入pattern的时候有个precondition_all_signals : C {"_pi" = 0000; "_po" =xxxx;}然后又调用Macro "test_setup"   ,在test_setup中又定义了C {"_pi" = NNNN; "_po" =xxxx;}
我的问题是,既然test_setup对pi po的值不关心,为何前面还有个precondition_all_signals,将_pi值全部变为0?
GMT+8, 2025-12-19 18:18 , Processed in 0.011265 second(s), 4 queries , Gzip On, Redis On.
