查看: 3214|回复: 1
[原创] Aletra internal PLL 约束错误如何解决
发表于 2018-10-30 16:56:18 | 显示全部楼层 |阅读模式
论坛的高手们,我用internal PLL 去产生多个不同频率时钟,加以约束的时候,出现一下警告。我没有明白那个相位警告,对时钟影响大吗?如何解决?
Warning (332056): PLL cross checking found inconsistent PLL clock settings:
        Warning (332056): Clock: cpld_10m_clk was found on node: U_core|cpld_clk_pll_ins|altpll_component|auto_generated|pll1|clk[0] with settings that do not match the following PLL specifications:
                Warning (332056): -phase (expected: 0.75, found: 0.00)
        Warning (332056): Clock: sys_clk_50m was found on node: U_core|cpld_clk_pll_ins|altpll_component|auto_generated|pll1|clk[1] with settings that do not match the following PLL specifications:
                Warning (332056): -phase (expected: 3.75, found: 0.00)
        Warning (332056): Clock: ifcclk was found on node: U_core|ifc_clk_ins|altpll_component|auto_generated|pll1|clk[0] with settings that do not match the following PLL specifications:
                Warning (332056): -phase (expected: 5.63, found: 0.00)
发表于 2018-10-31 15:16:19 | 显示全部楼层
这三个时钟的约束能否看一下?
GMT+8, 2025-12-30 22:45 , Processed in 0.012110 second(s), 4 queries , Gzip On, Redis On.
