楼主: smartzz
[原创] 经验分享Dumping VCS Annotated Stack问题!
发表于 2020-10-14 17:25:39 | 显示全部楼层
Good, Thanks very much.
发表于 2020-12-31 23:52:06 | 显示全部楼层
非常感谢,vcs可以跑起来了
发表于 2021-1-10 00:54:42 | 显示全部楼层
不必执念于高VCS版本,2014.03足以,只需将高版本VCS安装目录下etc文件夹下的uvm-1.2复制到2014.03的etc下,并建立uvm指向uvm-1.2的链接,就完成uvm升级了,当然UVM_HOME要指向这个uvm。那个两步的license可以产生至2049年,足够国产EDA诞生了
发表于 2021-9-17 19:16:23 | 显示全部楼层
can someone convert the .txt attachment to english please ? Even google translate fails !!
发表于 2021-9-17 21:25:54 | 显示全部楼层
kang.kang 发表于 2020-9-16 17:14
感谢,卡了两天了,这个工具解决了我的问题。
Which vcs version u tried. can you rewrite the steps in English
发表于 2021-10-22 16:09:12 | 显示全部楼层
感谢,解决了问题。
发表于 2021-10-22 19:30:37 | 显示全部楼层
vcs_vO-2018.09-SP2txt is such a precedure:
edit hostid and hostname and leave others then generate the dat file, edit the snpslmd path by  Line 2 with your scl path
update those two of your env variables, set the value which is matched to the dat, the portnum and the hostname matters here, it should be coherenced to the OS config, like /etc/hosts
at last reboot and setup the lmgrd again
发表于 2021-12-8 16:56:50 | 显示全部楼层
只用到2020年底有啥用
发表于 2022-1-18 16:29:24 | 显示全部楼层
谢谢大佬@@@@@@@@@@@@@@@@@
发表于 2022-2-16 23:29:47 | 显示全部楼层
感谢楼主分享~
GMT+8, 2025-12-30 18:28 , Processed in 0.423308 second(s), 5 queries , Gzip On, Redis On.
