查看: 9872|回复: 24
Latchup-Like Failure of Power-Rail ESD Clamp Circuit(2007 SCI)
发表于 2007-10-31 08:57:11 | 显示全部楼层 |阅读模式
Circuits in CMOS Integrated Circuits Under
System-Level ESD Test
Ming-Dou Ker and Cheng-Cheng Yen
Nanoelectronics & Gigascale Systems Laboratory
Institute of Electronics, National Chiao-Tung University, Hsinchu, Taiwan
Abstract
      Two different on-chip power-rail electrostatic
discharge (ESD) protection circuits, (1) with NMOS and PMOS
feedback; and (2) with cascaded PMOS feedback, have been
designed and fabricated in a 0.18-μm CMOS technology to
investigate their susceptibility to system-level ESD test. The
main purpose for adopting the feedback loop into the power-rail
ESD clamp circuits is to avoid the false triggering during a fast
power-up operation. However, during the system-level ESD test,
where the ICs in a microelectronics system have been powered
up, the feedback loop used in the power-rail ESD clamp circuit
provides the lock function to keep the main ESD device in a
“latch-on” state. The latch-on ESD device, which is often
designed with a larger device dimension to sustain high ESD
level, conducts a huge current between the power lines to
perform a latchup-like failure after the system-level ESD test.
The susceptibility of power-rail ESD clamp circuits with the
additional board-level noise filter to the system-level ESD test is
also investigated. To meet high system-level ESD specifications,
the chip-level ESD protection design should be considered with
the transient noise during system-level ESD stress.
Keywords- Electrostatic Discharge (ESD), system-level ESD
test, power clamp circuits, board-level noise filter.
abbr_b0ed6219df118821b571c14b86593e84.pdf
792.18 KB, 下载次数: 249 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-24 11:31:16 | 显示全部楼层
头像被屏蔽
发表于 2008-10-24 13:00:40 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-5-15 17:22:48 | 显示全部楼层
鼎鼎。。。。。
发表于 2010-5-16 02:47:39 | 显示全部楼层
Thank you so much!
发表于 2010-5-16 23:12:09 | 显示全部楼层
thanks~~
发表于 2010-10-26 22:51:09 | 显示全部楼层
XXX
XXX
发表于 2010-11-18 11:30:47 | 显示全部楼层
nice paper
发表于 2011-1-23 17:43:44 | 显示全部楼层
good!
发表于 2011-3-16 16:20:24 | 显示全部楼层
thanks a lot!!
GMT+8, 2025-12-27 04:24 , Processed in 0.021548 second(s), 6 queries , Gzip On, Redis On.
