查看: 2484|回复: 1
大家来帮我弄弄这个程序!!!!!!!!!!
发表于 2007-10-29 18:36:03 | 显示全部楼层 |阅读模式
这是个8位ALU程序,用quartus软件,它的仿真波形我弄不出来,大家来帮我弄弄吧!!!!
谁弄出仿真波形贴出来,我看看。。。。。。谢谢大家了!!!
LIBRARY    IEEE;
USE   IEEE.STD_LOGIC_1164.ALL;
USE   IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY   ALU181  IS
PORT(S:IN  STD_LOGIC_VECTOR(3 DOWNTO 0);
     A,B : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
     F : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
     COUT : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
     M,CN : IN STD_LOGIC;
     CO,FZ: OUT STD_LOGIC);
END ALU181;
ARCHITECTURE behav OF ALU181 IS
SIGNAL A9,B9,F9: STD_LOGIC_VECTOR(8 DOWNTO 0);
BEGIN
A9 <= '0' & A ; B9 <= '0' & B ;
PROCESS (M,CN,S,A9,B9)
BEGIN
CASE S IS
WHEN"0000"=>IF M='0' THEN F9<=A9+CN;ELSE F9<=NOT A9;END IF;
WHEN"0001"=>IF M='0' THEN F9<=(A9 OR B9)+CN;ELSE F9<=NOT(A9 OR B9);
     END IF;
WHEN"0010"=>IF M='0' THEN F9<=(A9 OR (NOT B9))+CN;
     ELSE F9<=(NOT A9)AND B9;END IF;
WHEN"0011"=>IF M='0' THEN F9<="000000000"-CN;ELSE F9<="000000000";
     END IF;
WHEN"0100"=>IF M='0' THEN F9<=A9+(A9 AND NOT B9)+CN;
     ELSE F9<=NOT(A9 AND B9);END IF;
WHEN"0101"=>IF M='0' THEN F9<=(A9 OR B9)+(A9 AND NOT B9)+CN;
     ELSE F9<=NOT B9;END IF;
WHEN"0110"=>IF M='0' THEN F9<=A9 -B9 - CN;ELSE F9<=A9 XOR B9;END IF;
WHEN"0111"=>IF M='0' THEN F9<=(A9 AND (NOT B9)) -CN;
     ELSE F9<=A9 AND(NOT B9); END IF;
WHEN"1000"=>IF M='0' THEN F9<=A9 + (A9 AND B9)+CN;
     ELSE F9<=(NOT A9) OR B9; END IF;
WHEN"1001"=>IF M='0' THEN F9<=A9+B9+CN;ELSE F9<=NOT(A9 XOR B9);
     END IF;
WHEN"1010"=>IF M='0' THEN F9<=(A9 OR(NOT B9))+(A9 AND B9)+CN;
     ELSE F9<=B9; END IF;
WHEN"1011"=>IF M='0' THEN F9<=(A9 AND B9) - CN; ELSE F9<=A9 AND B9;
     END IF;
WHEN"1100"=>IF M='0' THEN F9<=A9 + A9 + CN; ELSE F9<="000000001";
     END IF;
WHEN"1101"=>IF M='0' THEN F9<=(A9 OR B9)+A9+CN;
     ELSE F9<=A9 OR (NOT B9); END IF;
WHEN"1110"=>IF M='0' THEN F9<=(A9 OR(NOT B9))+A9+CN; ELSE F9<=A9
     OR B9; END IF;
WHEN"1111"=>IF M='0' THEN F9<=A9-CN; ELSE F9<=A9; END IF;
WHEN OTHERS =>F9<="000000000";
END CASE;
    IF(A9=B9) THEN FZ <='0'; END IF;
       END PROCESS;
    F<=F9(7 DOWNTO 0); CO <= F9(8);
    COUT <="0000" WHEN F9(8)='0' ELSE "0001";
END behav;
发表于 2007-10-30 13:34:16 | 显示全部楼层
仔细看了一下这个程序,应该可以实现啊,怎么会出不来仿真波型呢??
是不是你操作上的失误啊???????
GMT+8, 2025-12-12 04:39 , Processed in 0.015311 second(s), 6 queries , Gzip On, Redis On.
