查看: 2863|回复: 7
An output buffer for 3.3-V applications in a 0.13-μm(Ming-Dou Ker)
发表于 2007-9-28 11:32:53 | 显示全部楼层 |阅读模式
An output buffer for 3.3-V applications in a 0.13-μm 1/2.5-V CMOS process
期刊
S.-L. Chen and Ming-Dou Ker “An output buffer for 3.3-V applications in a 0.13-μm 1/2.5-V CMOS process,” IEEE Trans. on Circuits and Systems II: Express Briefs, vol. 54, no. 1, pp. 14-18, Jan. 2007.
摘要
With a 3.3-V interface, such as PCI-X application, high-voltage overstress on the gate oxide is a serious reliability problem in designing I/O circuits by using only 1/2.5-V low-voltage devices in a 0.13- m CMOS process. Thus, a new output buffer realized with low-voltage (1- and 2.5-V) devices to drive high-voltage signals for 3.3-V applications is proposed in this paper. The proposed output buffer has been fabricated in a 0.13- m 1/2.5-V 1P8M CMOS process with Cu interconnects. The experimental results have confirmed that the proposed output buffer can be successfully operated at 133 MHz without suffering high-voltage gate-oxide overstress in the 3.3-V interface. In addition, a new level converter that is realized with only 1- and 2.5-V devices that can convert 0/1-V voltage swing to 1/3.3-V voltage swing is also presented in this paper. The experimental results have also confirmed that the proposed level converter can be operated correctly.
[ 本帖最后由 semico_ljj 于 2007-9-28 11:37 编辑 ]
1084_TCAS2_SLChen_Ker_Output_Buffer.pdf
973.15 KB, 下载次数: 129 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-18 09:19:56 | 显示全部楼层
好东西!
发表于 2009-4-15 10:33:38 | 显示全部楼层
向楼主学习了
发表于 2009-4-15 23:07:47 | 显示全部楼层
好东西!
发表于 2009-4-28 23:00:50 | 显示全部楼层
3.3V的管子能用在5V么?
发表于 2010-5-26 14:46:54 | 显示全部楼层
我帮你顶一下
发表于 2010-5-26 16:28:27 | 显示全部楼层
thanks, thanks and thanks.
发表于 2011-5-11 16:36:43 | 显示全部楼层
向楼主学习了
GMT+8, 2025-12-7 03:38 , Processed in 0.031275 second(s), 7 queries , Gzip On, Redis On.
