楼主: dyjguilin
请教:下面这道题怎么做
发表于 2007-9-25 10:42:32 | 显示全部楼层
the answer is Vout = Vin * 200k*gm/(1+100k*gm)~2Vin
the left voltage, V1=Vin+Vgs
right ,    V2=Vgs
the left current, I1=V1*gm1=(Vin+Vgs)gm1
right         I2=V2*gm1=Vgs*gm1
gm1=gm/(1+R)
Ir=I1-I2=Vin*gm1
Vout=Ir*2R=Vin*gm1*2R=Vin*2R*gm/(1+R)=Vin*200k*gm/(1+100k*gm)~2*Vin
发表于 2007-9-25 10:47:21 | 显示全部楼层
原帖由 quifei 于 2007-9-17 19:22 发表
如何保证两个N管的VGS相等?因为两个100K电阻的电流不一样,
还是不是太明白
the same operation point
发表于 2007-9-25 10:51:10 | 显示全部楼层
原帖由 maturity 于 2007-9-15 15:45 发表
两倍电压放大器?放大倍数为两电阻比率。优点可能为:比率较精确,克服温度效应。不知复制电路有啥作用。
How do you get the conclusion?
accurate? independent on temp?  I donot think so.
GMT+8, 2025-9-18 14:31 , Processed in 0.011100 second(s), 3 queries , Gzip On, Redis On.
