查看: 3943|回复: 1
[求助] 怎么从工艺库里的参数求μncox、μpcox、vgs-vth?
发表于 2018-9-5 15:21:55 | 显示全部楼层 |阅读模式
怎么从工艺库里的参数求μncox、
μpcox、vgs-vth?
以下是工艺库参数...
   ******csmc 0.6um double poly mix process hspice model********************
*it is strongly recommended you read through all the note before your   *
*simulation                                                             *
* this model card includes models of hspice version:                    *
* 1)  normal and low vth mos device model libs                          *
*     section tt    : normal and low vth mos                            *
*     section ff    : normal and low vth mos                            *
*     section fs    : normal and low vth mos                            *
*     section sf    : normal and low vth mos                            *
*     section ss    : normal and low vth mos                            *
*  each lib includes four device models,listed below:                   *
*     a)model nmos nmos :  normal vth nmos                              *
*     b)model pmos pmos :  normal vth pmos                              *
*     c)model lvn  nmos :  low vth nmos                                 *
*     d)model lvp  pmos :  low vth pmos                                 *
* 2) typical depletion mos device model:                                *
*     section deptt                                                     *
*   this lib includes two device models                                 *
*     model depn nmos :  depletion nmos                                 *
*     model depp pmos :  depletion pmos                                 *
*  3)bjt device model:                                                  *
*     section bjt    :parasitic bjt model                               *
*     there are 3 bjt models in this lib:                               *
*     a)   model pnp10:  with emitter area = 100 um^2 (10x10)           *
*     b)   model pnp20: with emitter area = 400 um^2 (20x20)            *
*     c)   model pnp5: with emitter area = 25 um^2   (5x5)              *
*         usage example: q1 nc nb ne pnp5                               *
*                                        ( use default area=1)          *
*  to use these models directly by programming in this style:           *
*     include "lib_path/libfile_name" section_name                      *
*  ex: include "/home/user/csmc/s06mixddct10v04.scs" section=tt         *
*             for typical mos device                                    *
simulator lang=spectre
library csmc
section tt
parameters
+toxn     = 0                   vthn     = 0                   xln      = 0
+xwn      = 0                   cjn      = 0                   cjswn    = 0
+cgdon    = 0                   cgson    = 0                   cjswgn  = 0
+toxp     = 0                   vthp     = 0                   xlp      = 0
+xwp      = 0                   cjp      = 0                   cjswp    = 0
+cgdop    = 0                   cgsop    = 0                   cjswgp  = 0
+toxln     = 0                  vthln     = 0                  xlln      = 0
+xwln      = 0                  cjln      = 0                  cjswln    = 0
+cgdoln    = 0                  cgsoln    = 0                  cjswgln  = 0
+toxlp     = 0                  vthlp     = 0                  xllp      = 0
+xwlp      = 0                  cjlp      = 0                  cjswlp    = 0
+cgdolp    = 0                  cgsolp    = 0                  cjswglp  = 0
include "s06mixddct10v04.scs" section=spectrebase
include "s06mixddct10v04.scs" section=deptt
include "s06mixddct10v04.scs" section=bjt
endsection tt
section ff
parameters
+toxn     = -10e-10             vthn     = -1.49e-1            xln      = -1.96e-7
+xwn      = 1e-7                cjn      = -4.35e-5            cjswn    = -3.6489e-11
+cgdon    = -2e-11              cgson    = -2e-11              cjswgn  = -2.00e-15
+toxp     = -10e-10             vthp     = 1.9e-1              xlp      = -1.0e-7
+xwp      = 1.0e-7              cjp      = -8.208e-5           cjswp    = -4.177e-11
+cgdop    = -1.0e-11            cgsop    = -1.0e-11            cjswgp  = -2e-15
+toxln     = -10e-10            vthln     = -0.1               xlln      = -0.06e-6
+xwln      = 0.08e-6            cjln      = -4.35e-05          cjswln    = -3.65e-11
+cgdoln    = -2.00e-11          cgsoln    = -2.00e-11          cjswgln  = -2.00e-15
+toxlp     = -10e-10            vthlp     = 0.1                xllp      = -0.06e-6
+xwlp      = 0.08e-6            cjlp      = -8.2e-5            cjswlp    = -4.10e-11
+cgdolp    = -1e-11             cgsolp    = -1e-11             cjswglp  = -2e-15
endsection ff
section fs
parameters
+toxn     = -5e-10              vthn     = -0.75e-1            xln      = -0.96e-7
+xwn      = 5e-8                cjn      = -4.35e-5            cjswn    = -3.6489e-11
+toxp     = 5e-10               vthp     = -8.31e-2            xlp      = 2.74e-8
+xwp      = -0.5e-7              cjp      = 8.208e-5            cjswp    = 4.177e-11
+cgdop    = 1.0e-11            cgsop    = 1.0e-11             cjswgp  = 2e-15
+toxln     = -5e-10            vthln     = -0.05               xlln      = -0.03e-6
+xwln      = 0.04e-6            cjln      = -4.35e-05          cjswln    = -3.65e-11
+toxlp     = 5e-10               vthlp     = -0.05            xllp      = 0.03e-6
+xwlp      = -0.04e-6            cjlp      = 8.2e-5           cjswlp    = 4.10e-11
+cgdolp    = 1e-11              cgsolp    = 1e-11             cjswglp  = 2e-15
endsection fs
section sf
parameters
+toxn     = 5e-10               vthn     = 0.75e-1             xln      = 9.4e-8
+xwn      = -5e-8               cjn      = 4.35e-5             cjswn    = 3.6489e-11
+cgdon    = 2e-11               cgson    = 2e-11               cjswgn  = 2.00e-15
+toxp     = -5e-10              vthp     = 0.95e-1              xlp      = -5.26e-8
+xwp      = 0.5e-7              cjp      = -8.208e-5            cjswp    = -4.177e-11
+toxln     = 5e-10              vthln     = 0.05               xlln      = 0.03e-6
+xwln      = -0.04e-6           cjln      = 4.35e-05          cjswln    = 3.65e-11
+cgdoln    = 2.00e-11           cgsoln    = 2.00e-11          cjswgln  = 2.00e-15
+toxlp     = -5e-10             vthlp     = 0.05             xllp      = -0.03e-6
+xwlp      = 0.04e-6            cjlp      = -8.2e-5           cjswlp    = -4.10e-11
endsection sf
section ss
parameters
+toxn     = 10e-10               vthn     = 1.52e-1            xln      = 1.84e-7
+xwn      = -1e-7               cjn      = 4.35e-5             cjswn    = 3.6489e-11
+toxp     = 10e-10              vthp     = -1.9e-1             xlp      = 7.7e-8
+xwp      = -1.0e-7              cjp      = 8.208e-5            cjswp    = 4.177e-11
+toxln     = 10e-10            vthln     = 0.1               xlln      = 0.06e-6
+xwln      = -0.08e-6            cjln      = 4.35e-05          cjswln    = 3.65e-11
+toxlp     = 10e-10            vthlp     = -0.1                xllp      = 0.06e-6
+xwlp      = -0.08e-6            cjlp      = 8.2e-5            cjswlp    = 4.10e-11
endsection ss
section spectrebase
model nmos bsim3v3
+type =n
+lmin     = 0.6e-6              lmax     = 2.0e-5              wmin     = 0.8e-6
+wmax     = 2.0e-5              version  = 3.0
+tox      = 1.25e-08+toxn       xj       = 2.5000000e-07       nch      = 1.2721000e+17
+lln      = 1.0295000           lwn      = 1.0000000           wln      = 0.9340000
+wwn      = 2.0000000           lint     = 1.5200000e-07       ll       = -3.5900000e-14
+lw       = 0.00                lwl      = 0.00                wint     = 2.0200001e-07
+wl       = -9.4300000e-14      ww       = -5.1700000e-20      wwl      = 0.00
+mobmod   = 1                   binunit  = 2                   xl       = 0.00e+00+xln
+xw       = 0.00e+00+xwn        dwg      = -2.2914280e-08      dwb      = 1.3746710e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 0
+rd       = 0                   rs       = 0                   rsc      = 0
+rdc      = 0
+vth0     = 7.28e-01+vthn       k1       = 0.7409649           k2       = -1.5283380e-02
+k3       = 7.1778210           dvt0     = 14.8549000          dvt1     = 1.0209540
+dvt2     = -4.6828460e-02      dvt0w    = -8.0227880e-02      dvt1w    = 8.8635700e+04
+dvt2w    = 0.1900000           nlx      = 0.00                w0       = 1.3573220e-06
+k3b      = -4.7786870          ngate    = 1.0000000e+20
+vsat     = 7.7711460e+04       ua       = -7.4628200e-10      ub       = 2.6335220e-18
+uc       = 3.5986350e-11       rdsw     = 1.8026500e+03       prwb     = 1.9065101e-02
+prwg     = -3.4200580e-02      wr       = 0.9613520           u0       = 4.2603870e-02
+a0       = 0.4940039           keta     = -1.6965831e-02      a1       = 0.00
+a2       = 0.9900000           ags      = 1.9959440e-02       b0       = 8.6096910e-08
+b1       = -4.3232750e-07
+voff     = -9.6102280e-02      nfactor  = 1.0989590           cit      = 2.3121500e-04
+cdsc     = 4.8599650e-03       cdscb    = 9.1149930e-04       cdscd    = 0.00
+eta0     = 6.2591110e-03       etab     = -1.1673500e-02      dsub     = 0.2718996
+pclm     = 0.6415634           pdiblc1  = 9.6421800e-03       pdiblc2  = 1.5307820e-03
+pdiblcb  = -0.1822976          drout    = 0.1000000           pscbe1   = 2.7371760e+30
+pscbe2   = 4.6373430e-20       pvag     = 0.00                delta    = 1.0000000e-02
+alpha0   = 3.5e-6              beta0    = 30.0000000
+kt1      = -0.3333333          kt2      = -2.6930001e-02      at       = 1.2000000e+04
+ute      = -1.6454999          ua1      = 1.1130000e-09       ub1      = -1.0460000e-18
+uc1      = -6.6220000e-12      kt1l     = 0.00                prt      = 8.4800000e+02
+cj       = 4.35e-04+cjn        mj       = 0.4223898           pb       = 0.9590048
+cjsw     = 3.65e-10+cjswn      mjsw     = 0.1671139           pbsw     = 0.5406927
+cjswg    = 2e-14 +cjswgn       mjswg    = 0.33                pbswg    = 0.7
+cta      = 0                   ctp      = 0                   pta      = 0
+ptp      = 0                   js       = 1.00e-14            jsw      = 0.00
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.00e-10+cgdon
+cgso     = 2.00e-10+cgson      cgbo     = 1.0e-13             capmod   = 2
+nqsmod   = 0                   elm      = 5                   xpart    = 1
+cgsl     = 2.0000000e-10       cgdl     = 2.0000000e-10       ckappa   = 1.9920000
+cf       = 0.00                clc      = 8.0259140e-09       cle      = 2.0475841
+dlc      = 1.5184e-07          dwc      = 2.015e-07
model pmos bsim3v3
+type = p
+wmax     = 2.0e-5              version  = 3.1
+tox      = 1.30e-08+toxp       xj       = 3.0000001e-07       nch      = 2.5099999e+16
+lln      = 0.2000000           lwn      = 1.0000000           wln      = 1.0660000
+wwn      = 2.0000000           lint     = -1.3000000e-09      ll       = -1.3500000e-10
+lw       = 0.00                lwl      = 1.4900000e-15       wint     = 2.3999999e-07
+wl       = 5.5000000e-15       ww       = -8.2200000e-20      wwl      = 0.00
+mobmod   = 1                   binunit  = 2                   xl       = 0.00e+00+xlp
+xw       = 0.00e+00+xwp        dwg      = -2.9800001e-08      dwb      = 2.0800000e-08
+rdc      = 0
+vth0     = -1.02e+00+vthp      k1       = 0.4355000           k2       = 1.2700000e-02
+k3       = 11.1944000          dvt0     = 6.4793000           dvt1     = 0.9395000
+dvt2     = 8.7300000e-03       dvt0w    = 3.7900000e-02       dvt1w    = 0.00
+dvt2w    = 0.1900000           nlx      = 0.00                w0       = 2.9399999e-07
+k3b      = -2.3515999          ngate    = 1.0000000e+20
+vsat     = 9.4300000e+04       ua       = 1.9199999e-09       ub       = 7.7500000e-19
+uc       = -5.0000000e-11      rdsw     = 3.3300000e+03       prwb     = 9.9200000e-02
+prwg     = -3.7100000e-02      wr       = 0.9804000           u0       = 1.9200001e-02
+a0       = 0.2612000           keta     = -1.4800000e-02      a1       = 0.00
+a2       = 0.4000000           ags      = 2.0000000e-02       b0       = 3.1600001e-07
+b1       = -3.0300001e-07
+voff     = -0.1054000          nfactor  = 0.8294000           cit      = 9.8500000e-04
+cdsc     = 1.0000000e-10       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.1185000           etab     = -3.2900000e-03      dsub     = 0.5157000
+pclm     = 2.9535999           pdiblc1  = 1.0000000e-05       pdiblc2  = 1.2900000e-03
+pdiblcb  = 0.1900000           drout    = 3.0000000           pscbe1   = 3.7000000e+30
+pscbe2   = 1.0000000e-20       pvag     = 1.0000000           delta    = 1.0000000e-02
+alpha0   = 1.0e-6              beta0    = 30.0000000
+kt1      = -0.4763000          kt2      = -2.9050000e-02      at       = 1.0000000e+04
+ute      = -1.0000000          ua1      = 3.7500000e-09       ub1      = -7.1500000e-18
+uc1      = -5.0833000e-11      kt1l     = 0.00                prt      = -8.8300000e+02
+cj       = 8.21e-04+cjp        mj       = 0.5198076           pb       = 0.9180865
+cjsw     = 4.11e-10+cjswp      mjsw     = 0.2586436           pbsw     = 0.6054589
+cjswg    = 2.00e-14+cjswgp     mjswg    = 0.33                pbswg    = 0.7
+ptp      = 0                   js       = 1.00e-04            jsw      = 0.00
+n        = 1.0                 xti      = 3.0                 cgdo     = 1.00e-10+cgdop
+cgso     = 1.00e-10+cgsop      cgbo     = 1.0e-13             capmod   = 2
+cgsl     = 1.0000000e-10       cgdl     = 9.9592000e-11       ckappa   = 1.0000000
+cf       = 0.00                clc      = 5.0018750e-08       cle      = 0.8024064
+dlc      = -1.421085e-14       dwc      = 2.304e-07           vfbcv    = -1
model lvn bsim3v3
+type = n
+lmin     = 1.0e-6              lmax     = 2.0e-5              wmin     = 8.0e-7
+wmax     = 2.0e-5              tnom     = 25.0                version  = 3.2
+tox      = 1.25e-08+toxln      xj       = 1.0000000e-07
+nch      = 7.1525000e+16       lln      = 1.0000000           lwn      = 1.0000000
+wln      = 1.0000000           wwn      = 1.0000000           lint     = 1.0337500e-07
+ll       = -3.7391000e-14      lw       = -1.1304819e-13      lwl      = -1.6379501e-20
+wint     = 2.0677000e-07       wl       = 4.8710700e-15       ww       = -6.2206650e-14
+wwl      = -1.5963582e-19      mobmod   = 1                   binunit  = 2
+xl       = 0.00e+00+xlln        xw       = 0.00e+00+xwln        dwg      = -1.7443986e-08
+dwb      = 1.3401290e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 69.48
+rdc      = 0
+vth0     = 3.57e-01+vthln      pvth0    = 2.1771500e-14       k1       = 0.5907000
+k2       = -2.6599987e-04      k3       = 3.2682290           dvt0     = 1.6550127
+dvt1     = 0.4458654           dvt2     = -0.1236620          dvt0w    = -0.3401813
+dvt1w    = 2.4880463e+06       dvt2w    = 0.2375000           nlx      = 1.4412889e-07
+w0       = 1.0198416e-10       k3b      = -2.2018001          ngate    = 1.0000000e+23
+vfb      = -0.9709756
+vsat     = 7.8906000e+04       pvsat    = -7.5000010e-09      ua       = 2.7607008e-10
+ub       = 1.9582000e-18       uc       = 4.2575840e-11       rdsw     = 6.5700000e+02
+prwb     = -2.7900001e-02      prwg     = 6.8000000e-02       wr       = 1.0000000
+u0       = 5.1113020e-02       a0       = 1.2841400           la0      = -6.3800000e-07
+pa0      = -1.7500000e-12      keta     = -2.0721501e-02      lketa    = -5.0000000e-09
+wketa    = 7.2000000e-09       pketa    = 9.9999980e-15       a1       = 0.00
+a2       = 0.9900000           ags      = 0.1818700           lags     = 1.0000002e-07
+pags     = 5.5000010e-14       b0       = 3.8649000e-07       b1       = 7.2000000e-08
+voff     = -7.5898350e-02      nfactor  = 1.7409346           cit      = -4.7077630e-04
+cdsc     = 2.2212162e-03       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.2010600           etab     = -0.1045700          dsub     = 0.5249688
+pclm     = 1.8257079           pdiblc1  = 1.3913199e-02       pdiblc2  = 7.6000000e-03
+pdiblcb  = -0.1250000          drout    = 3.0000000           pscbe1   = 1.0000000e+30
+alpha0   = 2.1000001e-06       alpha1   = 0.00                beta0    = 30.0000000
+kt1      = -0.3713394          kt2      = 0.00                at       = 3.5575000e+04
+ute      = -0.8520300          ua1      = 6.4700000e-09       ub1      = -5.7525000e-18
+uc1      = -8.4126030e-11      kt1l     = -1.0000000e-20      prt      = 0.00
+cj       = 4.35e-04+cjln       mj       = 0.4223898           pb       = 0.9590048
+cjsw     = 3.65e-10+cjswln     mjsw     = 0.1671139           pbsw     = 0.5406927
+cjswg    = 2e-14+cjswgln       mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.00e-10+cgdoln
+cgso     = 2.00e-10+cgsoln     cgbo     = 1.0e-13             capmod   = 2
+dlc      = 1.5184e-07          dwc      = 2.015e-07           vfbcv    = -1
+acde     = 1                   moin     = 15                  noff     = 1
+voffcv   = 0
model lvp bsim3v3
+type  =   p
+tox      = 1.35e-08+toxlp      xj       = 2.0000000e-07
+nch      = 4.3415000e+16       lln      = 1.0000000           lwn      = 1.0000000
+wln      = 1.0000000           wwn      = 1.0000000           lint     = 4.5000000e-11
+ll       = 7.1309870e-14       lw       = -2.5312499e-13      lwl      = -1.8867350e-19
+wint     = 1.9834999e-07       wl       = -2.1250344e-13      ww       = -8.1235000e-14
+wwl      = -1.1351710e-19      mobmod   = 1                   binunit  = 2
+xl       = 0.00e+00+xllp       xw       = 0.00e+00+xwlp     dwg      = -1.2478000e-08
+dwb      = 1.1176000e-08
+ldif     = 0.00                hdif     = 5.00e-07            rsh      = 100
+rdc      = 0
+vth0     = -4.37e-01+vthlp     lvth0    = -5.0000000e-08      wvth0    = -1.3749999e-08
+k1       = 0.4447000           k2       = 2.8000001e-02       k3       = 12.7750040
+dvt0     = 0.6240000           dvt1     = 0.1589000           dvt2     = -3.0400001e-02
+dvt0w    = -2.6686111e-02      dvt1w    = 1.5167305e+05       dvt2w    = -4.9315170
+nlx      = 3.9174720e-07       w0       = -1.3947984e-07      k3b      = -0.5316000
+ngate    = 1.0000000e+23       vfb      = -0.6731328
+vsat     = 1.0256806e+05       ua       = 4.8324240e-10       ub       = 2.2916292e-18
+uc       = -4.1300600e-11      rdsw     = 3.0969299e+03       prwb     = 9.7805430e-03
+prwg     = -5.0262350e-02      wr       = 1.0000000           u0       = 1.6230177e-02
+a0       = 0.3915754           keta     = -6.5810000e-03      lketa    = -2.4800000e-08
+wketa    = 7.0000000e-09       a1       = 0.00                a2       = 0.4000000
+ags      = 1.5620256e-04       b0       = 1.1107368e-06       b1       = 2.3536975e-06
+voff     = -0.4500000          nfactor  = 2.9005730           cit      = -1.5379302e-03
+cdsc     = 0.00                cdscb    = 1.0000000e-20       cdscd    = 0.00
+eta0     = 0.3251730           etab     = 0.00                dsub     = 0.5334910
+pclm     = 4.1747260           pdiblc1  = 2.4428440e-02       pdiblc2  = 1.8528653e-03
+pdiblcb  = 0.1250000           drout    = 3.0000000           pscbe1   = 3.3333330e+08
+alpha0   = 2.4800001e-02       alpha1   = 0.00                beta0    = 91.0000000
+kt1      = -0.5093207          kt2      = -5.6334000e-03      at       = 6.9622000e+03
+ute      = -1.3946000          ua1      = -6.8275000e-10      ub1      = -3.4619000e-19
+uc1      = -7.2356000e-11      kt1l     = -2.1118000e-08      prt      = 1.2000000e+02
+cj       = 8.21e-04+cjlp       mj       = 0.5198076           pb       = 0.9180865
+cjsw     = 4.11e-10+cjswlp     mjsw     = 0.2586436           pbsw     = 0.6054589
+cjswg    = 2.00e-14+cjswglp    mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 1.00e-10+cgdolp
+cgso     = 1.00e-10+cgsolp     cgbo     = 1.0e-13             capmod   = 2
+voffcv   = 0
endsection spectrebase
section deptt
model depn bsim3v3
+type = n
+lmin     = 0.0e+0              lmax     = 1.0e-3              wmin     = 0.0e+0
+wmax     = 1.0e-3              tnom     = 27.0                version  = 3.2
+tox      = 1.25e-08            xj       = 2.0000000e-07
+nch      = 2.1884999e+16       lln      = 0.3630000           lwn      = 1.0000000
+wln      = 0.6680689           wwn      = 0.4576737           lint     = 2.9300000e-09
+ll       = 9.2800000e-10       lw       = 0.00                lwl      = -3.8900000e-16
+wint     = 3.2745500e-07       wl       = -2.6153500e-12      ww       = -3.4738230e-10
+wwl      = 0.00                mobmod   = 2                   binunit  = 2
+xl       = 0.00                xw       = 0.00                dwg      = -1.7503099e-08
+dwb      = 2.8467641e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 70
+rdc      = 0
+vth0     = -0.2970000          k1       = 0.2824182           k2       = 5.0140220e-02
+k3       = 4.0372620           dvt0     = 0.6612508           dvt1     = 0.9038930
+dvt2     = 0.1900000           dvt0w    = 4.1514530e-03       dvt1w    = 1.0710410e-30
+dvt2w    = 0.1900000           nlx      = 2.2592779e-30       w0       = -3.0283161e-07
+k3b      = -1.0166310          ngate    = 1.0000000e+23       vfb      = -2.0755069
+vsat     = 8.1000000e+04       ua       = -3.5502000e-11      ub       = 2.3591050e-18
+uc       = -8.3053270e-11      rdsw     = 1.2858920e+03       prwb     = 1.2074960e-02
+prwg     = -4.0917670e-02      wr       = 0.9444284           u0       = 4.7100000e-02
+a0       = -0.1000000          keta     = -6.0882870e-03      a1       = 0.00
+a2       = 0.9900000           ags      = 1.7771060e-02       b0       = 2.7637839e-07
+b1       = -3.7861800e-07
+voff     = -0.1033449          nfactor  = 2.0000000           cit      = -2.1038590e-04
+cdsc     = 0.00                cdscb    = 0.00                cdscd    = 0.00
+eta0     = 0.00                etab     = -2.4141900e-03      dsub     = 0.1000000
+pclm     = 3.0369000           pdiblc1  = 0.1000000           pdiblc2  = 2.1576029e-03
+pdiblcb  = 6.5356970e-02       drout    = 0.5992727           pscbe1   = 3.4641020e+08
+alpha0   = 0.00                alpha1   = 0.00                beta0    = 30.0000000
+kt1      = -0.1100000          kt2      = 2.2000000e-02       at       = 3.3000000e+04
+ute      = -1.5000000          ua1      = 4.3100000e-09       ub1      = 7.6100000e-18
+uc1      = -5.6000000e-11      kt1l     = 0.00                prt      = 0.00
+cj       = 2e-14               mj       = 0.5                 pb       = 1
+cjsw     = 2e-14               mjsw     = 0.33                pbsw     = 1
+cjswg    = 2e-14               mjswg    = 0.33                pbswg    = 0.7
+n        = 1.0                 xti      = 3.0                 cgdo     = 2.5597e-10
+cgso     = 1.8102e-10          cgbo     = 1.0e-13             capmod   = 2
+nqsmod   = 0                   elm      = 5                   xpart    = 0
+cgsl     = -2.4300000e-17      cgdl     = -2.4300000e-17      ckappa   = 0.6000000
+cf       = 0.00                clc      = 7.1776660e-06       cle      = -2.0000000
+dlc      = -2.43e-17           dwc      = -2.43e-17           vfbcv    = -1.1241
+voffcv   = 0
model depp bsim3v3
+type = p
+nch      = 7.5600000e+16       lln      = 2.0000000           lwn      = 1.0000000
+wln      = 2.0000000           wwn      = 0.3500000           lint     = 3.7498580e-09
+ll       = 1.8819650e-20       lw       = 0.00                lwl      = -7.4997160e-26
+wint     = 4.4669360e-07       wl       = -2.3331970e-20      ww       = -2.5349129e-09
+xl       = 0.00                xw       = 0.00                dwg      = -1.9926020e-08
+dwb      = 3.8324790e-08
+ldif     = 0.00                hdif     = 6.00e-07            rsh      = 150
+rdc      = 0
+vth0     = 0.2639070           k1       = 0.5843000           k2       = 5.4800000e-03
+k3       = 27.1811010          dvt0     = 0.2507000           dvt1     = 5.2100000e-02
+dvt2     = 5.0200000e-02       dvt0w    = 2.0800000e-09       dvt1w    = 1.8800000e+05
+dvt2w    = 4.5600000e-02       nlx      = 0.00                w0       = -6.9220100e-09
+k3b      = 0.7294000           ngate    = 1.0000000e+23       vfb      = -0.5289000
+vsat     = 1.2251250e+05       ua       = 6.4456430e-10       ub       = 1.2172310e-18
+uc       = -1.7322660e-10      rdsw     = 1.4992140e+03       prwb     = -0.2000000
+prwg     = 0.1000000           wr       = 1.0218900           u0       = 1.4562040e-02
+a0       = 0.2884466           keta     = -1.3918980e-02      a1       = 0.00
+a2       = 0.4000000           ags      = 2.0000000e-02       b0       = 1.6545310e-07
+b1       = -4.0667760e-07
+voff     = -0.3000000          nfactor  = 2.0000000           cit      = 2.7624480e-03
+cdsc     = 1.4110730e-03       cdscb    = 0.00                cdscd    = 0.00
+eta0     = 8.9858010e-04       etab     = 0.00                dsub     = 0.1000000
+pclm     = 4.6821430           pdiblc1  = 0.1000000           pdiblc2  = 1.8944791e-02
+pdiblcb  = 0.1000000           drout    = 2.9999909           pscbe1   = 3.4641020e+08
+n        = 1.0                 xti      = 3.0                 cgdo     = 3.4925e-10
+cgso     = 6.3816e-09          cgbo     = 1.0e-13             capmod   = 2
+cgsl     = -2.4286130e-17      cgdl     = -2.4286130e-17      ckappa   = 0.6000000
+cf       = 0.00                clc      = 4.9500010e-08       cle      = 0.9110001
+dlc      = -2.428613e-17       dwc      = -2.428613e-17       vfbcv    = -1.6812
+voffcv   = 0
endsection
*************************bjt model*********************************
section bjt
model pnp20 bjt
+type= pnp                      is       = 1.01e-16            bf       = 16.3979
+nf       = 0.9909              vaf      = 261.3346            ikf      = 1.46e-03
+ise      = 4.38e-15            ne       = 1.9797              br       = 0.6531
+nr       = 0.8241              var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 40.7749
+irb      = 0.0181              rbm      = 9.359               re       = 0.0504
+rc       = 34.1265             xti      = 0.1254              eg       = 1.3133
+cje      = 0.00                vje      = 0.7                 mje      = 0.5
+tf       = 1.00e-10            xtf      = 1.0                 vtf      = 10.0
+itf      = 0.1                 cjc      = 0.00                vjc      = 0.7
+mjc      = 0.5                 xcjc     = 0.5                 fc       = 0.75
+cjs      = 0.00                vjs      = 0.75                mjs      = 0.5
+tr       = 0.00                ptf      = 0.00                kf       = 0.00
+af       = 1.0                 nkf      = 0.5                 cbcp     = 0.00
+cbep     = 0.00                ccsp     = 0.00
+tnom     = 27.0                tlev     = 0                   tlevc    = 0
+xtb      = 1.0
model pnp5 bjt
+type= pnp                      is       = 9.60e-18            bf       = 20.8917
+nf       = 0.994               vaf      = 175.6223            ikf      = 4.91e-04
+ise      = 8.94e-16            ne       = 2.2532              br       = 0.7533
+nr       = 0.796               var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 127.485
+irb      = 0.5075              rbm      = 9.3901              re       = 0.1002
+rc       = 33.7418             xti      = 10.46               eg       = 1.0678
+xtb      = 1.73
model pnp10 bjt
+type= pnp                      is       = 2.92e-17            bf       = 18.8029
+nf       = 0.9922              vaf      = 228.6814            ikf      = 9.80e-04
+ise      = 2.93e-17            ne       = 1.3754              br       = 0.1981
+nr       = 0.8232              var      = 10.0                ikr      = 1.5
+isc      = 1.00e-17            nc       = 1.5                 rb       = 71.3996
+irb      = 0.0904              rbm      = 9.4964              re       = 0.1344
+rc       = 20.8954             xti      = 0.1                 eg       = 1.2806
+xtb      = 1.0
endsection bjt
*    resistor models      *
* total 6 kinds of resistors are available in this model             *
* lib and they're         *
* 1) nwell resistor        *
* 2) n+ resistor         *
* 3) p+ resistor         *
* 4) poly1 resistor        *
* 5) poly2 resistor        *
* 6) hr resistor(either rsh=5k or 1k to can be chosen)    *
* usage example: x1 n1 n2 rnwell l=100u w=8u     *
* specially,for hr resistor,there are two option(rsh=5k and rsh=1k) to be chosen. *
* but couldn't use two hr resistors at the same time in simulation.  *
* the coefficients of resistor are as follows:                                          *
*  resistor        *
*  type   |rsh(ohm/sq) | dl(um) | dw(um) |   vc1   |   vc2   |   tc1   |   tc2          *
*  nwell     849.06      -0.248   1.399   8.48e-03  9.82e-04  5.24e-03  9.56e-06        *
*  nplus     79.10       -0.246   -0.366  1.05e-03  1.34e-03  1.73e-03  -6.17e-07       *
*  pplus     121.71      -0.925   -0.400  -2.35e-03 7.22e-04  9.40e-04  1.40e-06        *
*  poly1     27.53       0.167    0.212   2.32e-04  1.37e-03  7.75e-04  -3.42e-07       *
*  poly2     27.75       0.279    0.419   1.19e-03  2.56e-03  7.08e-04  -2.53e-07       *
*  hr(5k)    4545.68     1.144    0.055   -2.66e-03 -1.81e-03 -4.68e-03 1.58e-05        *
*  hr(1k)    995.792     1.443    0.162   -4.36e-03 -2.73e-03 -3.04e-03 1.15e-05        *
*  r=rsh*(l-dl)/(w-dw)*(1+vc1*|dv|+vc2*dv^2)(1+tc1*(t-tnom)+tc2*(t-tnom)^2)             *
section res
ahdl_include "res_va.va"
******************nwell resistor ********************************************************
subckt rnwell n1 n2
parameters w=1u l=1u
r1 (n1 n2) res_va w=w l=l rsh=849.06
+dl=-0.248u dw=1.399u
+ptc1=5.24e-03 ptc2=9.56e-06
+pvc1=8.48e-03 pvc2=9.82e-04
ends rnwell
***************nplus resistor ***********************************************************
subckt rnplus n1 n2
r1 (n1 n2) res_va w=w l=l rsh=79.10
+dl=-0.246u dw=-0.366u
+ptc1=1.73e-03 ptc2=-6.17e-07
+pvc1=1.05e-03 pvc2=1.34e-03
ends rnplus
***************pplus resistor ***********************************************************
subckt rpplus n1 n2
r1 (n1 n2) res_va w=w l=l rsh=121.71
+dl=-0.925u dw=-0.400u
+ptc1=9.40e-04 ptc2=1.40e-06
+pvc1=-2.35e-03 pvc2=7.22e-04
ends rpplus
***************poly1 resistor ***********************************************************
subckt rpoly1 n1 n2
r1 (n1 n2) res_va w=w l=l rsh=27.53
+dl=0.167u dw=0.212u
+ptc1=7.75e-04 ptc2=-3.42e-07
+pvc1=2.32e-04 pvc2=1.37e-03
ends rpoly1
***************poly2 resistor ***********************************************************
subckt rpoly2 n1 n2
r1 (n1 n2) res_va w=w l=l rsh=27.75
+dl=0.279u dw=0.419u
+ptc1=7.08e-04 ptc2=-2.53e-07
+pvc1=1.19e-03 pvc2=2.56e-03
ends rpoly2
***************hr resistor(rsh=5k) ******************************************************
*subckt rhr5k n1 n2
*parameters w=1u l=1u
*r1 (n1 n2) res_va w=w l=l rsh=4545.68
*+dl=1.144u dw=0.055u
*+ptc1=-4.68e-03 ptc2=1.58e-05
*+pvc1=-2.66e-03 pvc2=-1.81e-03
*ends rhr5k
***************hr resistor(rsh=1k) ******************************************************
subckt rhr1k n1 n2
r1 (n1 n2) res_va w=w l=l rsh=995.792
+dl=1.443u dw=0.162u
+ptc1=-3.042e-03 ptc2=1.150e-05
+pvc1=-4.355e-03 pvc2=-2.733e-03
ends rhr1k
endsection res
endlibrary csmc
发表于 2022-9-7 10:33:01 | 显示全部楼层
没人回,帮你顶下,要是楼主知道了,希望也分享一下
GMT+8, 2025-12-23 22:59 , Processed in 0.018523 second(s), 3 queries , Gzip On, Redis On.
