查看: 13861|回复: 21
[求助] 求十字交叉金属线去线头自动打孔的脚本!拜谢!
发表于 2018-7-25 09:16:24 | 显示全部楼层 |阅读模式
发表于 2018-7-30 15:04:22 | 显示全部楼层
You can write a skill Script to realize it .
发表于 2018-7-30 15:40:50 | 显示全部楼层
这个真是6 啊,同求
发表于 2018-8-2 09:55:30 | 显示全部楼层
我也想知道自动打孔技术  51的
发表于 2018-8-3 21:01:20 | 显示全部楼层
老哥,同求
发表于 2018-8-5 20:22:26 | 显示全部楼层
61到是可以自动打孔,但是取不了线头
发表于 2018-8-5 22:36:22 | 显示全部楼层
skill去计算交叠区域,然后打孔,应该不会很复杂的。
发表于 2019-10-21 21:15:30 | 显示全部楼层
同求
发表于 2019-10-22 11:18:05 | 显示全部楼层
好想法,可研究研究
发表于 2019-11-5 16:54:38 | 显示全部楼层
hiSetBindKey("Layout" "<Key>G" "xiubian()")
procedure(xiubian()
        object_List=geGetSelSet()
        objectA=car(object_List)
        pointsA=objectA~>points
        widthA=objectA~>width
        objectB=cadr(object_List)
        pointsB=objectB~>points
        widthB=objectB~>width
        if(car(car(pointsA))==car(cadr(pointsA)) then
                pointsShu=pointsA
                widthShu=widthA
                object_Shu=objectA
                pointsHeng=pointsB
                widthHeng=widthB
                object_Heng=objectB
                shoubian()
        else
                pointsShu=pointsB
                widthShu=widthB
                object_Shu=objectB
                pointsHeng=pointsA
                widthHeng=widthA
                object_Heng=objectA
                shoubian()
procedure(shoubian()
        y1Shu=cadr(car(pointsShu))
        y2Shu=cadr(cadr(pointsShu))
        yMaxShu=max(y1Shu y2Shu)
        yMinShu=min(y1Shu y2Shu)
        x1Heng=car(car(pointsHeng))
        x2Heng=car(cadr(pointsHeng))
        xMaxHeng=max(x1Heng x2Heng)
        xMinHeng=min(x1Heng x2Heng)
        xShu=car(car(pointsShu))
        yHeng=cadr(car(pointsHeng))
        when((xMaxHeng-xShu)<(xShu-xMinHeng)&&x1Heng<x2Heng
                xHeng_new=xShu+widthShu/2
                object_Heng~>points=list(car(pointsHeng) rplaca(cadr(pointsHeng) xHeng_new))
        when((xMaxHeng-xShu)<(xShu-xMinHeng)&&x1Heng>x2Heng
                object_Heng~>points=list(rplaca(car(pointsHeng) xHeng_new) cadr(pointsHeng))
        when((xMaxHeng-xShu)>(xShu-xMinHeng)&&x1Heng<x2Heng
                xHeng_new=xShu-widthShu/2
        when((xMaxHeng-xShu)>(xShu-xMinHeng)&&x1Heng>x2Heng
        when((yMaxShu-yHeng)>(yHeng-yMinShu)&&y1Shu<y2Shu
                yShu_new=yHeng-widthHeng/2
                remove_cell=cadr(car(pointsShu))
                object_Shu~>points=list(remove(remove_cell append1(car(pointsShu) yShu_new)) cadr(pointsShu))
        when((yMaxShu-yHeng)>(yHeng-yMinShu)&&y1Shu>y2Shu
                remove_cell=cadr(cadr(pointsShu))
                object_Shu~>points=list(car(pointsShu) remove(remove_cell append1(cadr(pointsShu) yShu_new)))
        when((yMaxShu-yHeng)<(yHeng-yMinShu)&&y1Shu<y2Shu
                yShu_new=yHeng+widthHeng/2
        when((yMaxShu-yHeng)<(yHeng-yMinShu)&&y1Shu>y2Shu
GMT+8, 2025-12-17 16:28 , Processed in 0.036764 second(s), 6 queries , Gzip On, Redis On.
