查看: 8405|回复: 21
柯明道-Design on power-rail ESD clamp circuit 130-nm CMOS process
发表于 2007-9-6 16:57:25 | 显示全部楼层 |阅读模式
論文名稱Design on power-rail ESD clamp circuit for 3.3-V I/O interface by using only 1-V/2.5-V low-voltage devices in a 130-nm CMOS process
期刊Ming-Dou Ker, W.-Y. Chen, and K.-C. Hsu, “Design on power-rail ESD clamp circuit for 3.3-V I/O interface by using only 1-V/2.5-V low-voltage devices in a 130-nm CMOS process,”IEEE Trans. on Circuits and Systems I: Regular Papers, vol. 53, no. 10, pp. 2187-2193, Oct. 2006.
摘要        A new power-rail electrostatic discharge (ESD) clamp circuit for application in 3.3-V mixed-voltage input–output (I/O) interface is proposed and verified in a 130-nm 1-V/2.5-V CMOS process. The devices in this power-rail ESD clamp circuit are all 1-V or 2.5-V low-voltage nMOS/pMOS devices, which are specially designed without suffering the gate-oxide reliability issue under 3.3-V I/O interface applications. A special ESD detection circuit realized with the low-voltage devices is designed and added in the power-rail ESD clamp circuit to improve ESD robustness of ESD clamp devices by substrate-triggered technique. The experimental results verified in a 130-nm CMOS process have proven the excellent effectiveness of this new proposed power-rail ESD clamp circuit.
關鍵字Electrostatic discharge (ESD), ESD protection
circuit, high-voltage tolerant, power-rail ESD clamp circuit,
919_Ker_WYChen_KCHsu_TCAS1_Oct_2006.pdf
714.78 KB, 下载次数: 327 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-10-5 21:47:35 | 显示全部楼层
xiexie
发表于 2008-2-19 10:45:07 | 显示全部楼层
Thankyou
发表于 2008-2-22 13:51:20 | 显示全部楼层
保護元件的設計非常重要喔
发表于 2009-2-11 20:42:54 | 显示全部楼层
xiexie
发表于 2009-4-19 23:31:07 | 显示全部楼层
thanks.
发表于 2010-3-16 17:44:41 | 显示全部楼层
thx for sharing
发表于 2011-7-19 10:10:58 | 显示全部楼层
ding!!1
发表于 2011-7-23 20:53:13 | 显示全部楼层
学习学习。
发表于 2011-11-22 15:14:52 | 显示全部楼层
谢谢楼主
GMT+8, 2025-12-25 23:47 , Processed in 0.021193 second(s), 7 queries , Gzip On, Redis On.
