查看: 2768|回复: 1
弱问:关于VREF
发表于 2007-8-31 10:03:40 | 显示全部楼层 |阅读模式
看Cyclone II的一个handbook,里面有这么一句
If a bank uses a voltage-referenced I/O standard, then these pins are used as the voltage-reference pins for the bank. If voltage reference I/O standards are not used in the bank, the VREF pins are available as user I/O pins.
问题是怎么判断一个bank有没有使用voltage-referenced I/O standard?
发表于 2007-8-31 10:39:33 | 显示全部楼层
it depends on what kind of interface you choose to implement in this bank. For example, if you want to implement a DDR interface, you should use VREF as a reference voltage.
GMT+8, 2025-12-26 10:55 , Processed in 0.225076 second(s), 6 queries , Gzip On, Redis On.
