查看: 3492|回复: 1
在使用QUARTUSII中遇到的问题
发表于 2007-8-28 16:37:39 | 显示全部楼层 |阅读模式
在使用QUARTUS II编译时出现如下错误,编译无法进行下去
Warning: Can't find design file none
Info: Smart recompilation skipped module Analysis & Synthesis because it is not required
Info: Smart recompilation skipped module Fitter because it is not required
Info: Smart recompilation skipped module Assembler because it is not required
Info: Smart recompilation skipped module Timing Analyzer because it is not required
Info: Quartus II Full Compilation was successful. 0 errors, 1 warning
虽然可以先进行语法编译,再进行全局编译可以使编译进行下去,但是这个错误仍然存在。
说一下,我是在使用了signal tap II时,加了个观察信号,然后重新编译,就变成这样了,不知道该怎样解决
谁帮我分析一下好吗,谢谢了
发表于 2007-9-3 11:35:11 | 显示全部楼层
signal tap 2我还没用过哪
GMT+8, 2025-12-24 11:12 , Processed in 0.018406 second(s), 7 queries , Gzip On, Redis On.
