楼主: faithfully
Architectures.For.Rf.Frequency.Synthesizers
发表于 2012-2-28 23:24:45 | 显示全部楼层
感謝分享!!謝謝!!
发表于 2012-5-5 08:43:32 | 显示全部楼层
感謝分享!!謝謝!!
发表于 2012-7-26 15:52:43 | 显示全部楼层
看來不錯, 下來參考看看~
发表于 2012-9-3 15:48:49 | 显示全部楼层
看了很不错,赞一个
发表于 2012-11-29 21:14:33 | 显示全部楼层
good!!
发表于 2012-12-6 15:59:49 | 显示全部楼层
Multi-loop synthesizers
Many high performance synthesizers use several loops that incorporate both mixers and digital dividers. By using these techniques it is possible to produce high performance wide range signal sources with very small step sizes. If only a single loop is used then there may be short falls in the level of performance.
There is a large variety of ways in which multi-loop synthesizers can be made, dependent upon the requirements of the individual system. However as an illustration a two loop system used as an example. This uses one loop to give the smaller steps and the second provides larger steps. This principle can be expanded to give wider ranges and smaller steps.
发表于 2012-12-6 16:08:18 | 显示全部楼层
发表于 2012-12-12 12:19:37 | 显示全部楼层
回复 1# faithfully
多谢!
发表于 2013-1-10 02:34:21 | 显示全部楼层
不错不错不错
发表于 2013-1-21 07:43:16 | 显示全部楼层
不错 haha
GMT+8, 2025-12-17 03:57 , Processed in 0.018273 second(s), 4 queries , Gzip On, Redis On.
