查看: 4453|回复: 4
[讨论] EZ-USB-FX3的使用
发表于 2018-4-3 19:39:21 | 显示全部楼层 |阅读模式
cypress 的EZ-USB-FX3器件允许设计者将USB集成到他们的系统中,上网查询了一下芯片型号大概是CYUSB3014,最常见的应用是作为同步从设备FIFO接口,用于很多和FPGA的连接中,使用方法和上一代的68013(USB2.0)芯片差不多。欢迎大家讨论一下对这个芯片的用法和看法
发表于 2018-4-6 21:48:00 | 显示全部楼层
Use Synchronous Slave FIFO Read Sequence or  Synchronous Slave FIFO Write Sequence to communicate with FPGA or external device.
 楼主| 发表于 2018-4-16 21:17:35 | 显示全部楼层
回复 2# duffrose
Reading the application note AN65974, but I have some trouble with watermark and boot option. can you give me some  suggestion?
发表于 2018-5-9 17:29:42 | 显示全部楼层
I am a hardware guy and build FPGA to transmit data to FX3. Not familiar with firmware code.
 楼主| 发表于 2018-5-22 21:13:56 | 显示全部楼层
回复 4# duffrose
    I am also a hardware guy. When I design the all system and build FPGA to transmit data to FX3, my boss tell me that I should design an application in PC to receive or send data.
GMT+8, 2025-12-30 23:19 , Processed in 0.017316 second(s), 3 queries , Gzip On, Redis On.
