查看: 4163|回复: 1
[求助] synopsys,snug登录注册问题
发表于 2018-2-2 11:35:27 | 显示全部楼层 |阅读模式
各位,登录了synopsys的账号,在SNUG的官网中,点击某一篇文章,提示:
UnauthorizedThis server could not verify that you are authorized to access the document requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesn't understand how to supply the credentials required.
这是什么意思,该怎么才能有授权
谢谢
发表于 2018-3-4 19:17:06 | 显示全部楼层
有synopsys 的license. 里面会有一个Site ID. 才能下载
GMT+8, 2025-12-18 05:43 , Processed in 0.012660 second(s), 3 queries , Gzip On, Redis On.
