查看: 2757|回复: 1
[原创] UVM1.2有哪些改进?
发表于 2018-1-18 14:12:43 | 显示全部楼层 |阅读模式
对于看源码这种事真的是头疼,有哪些大神对UVM1.2有比较深的理解,分享一下,在UVM1.1d上做了哪些改进呢
发表于 2018-1-18 17:57:28 | 显示全部楼层
a.        automatic phase raising/dropping by seq.set_automatic_phase_objection(1).
b.        starting_phase in uvm_sequence_base is protected now, use set_starting_phase and get_starting_phase to set and get the value respectively.
c.        set_config_int/set_config_object/set_config_string are deprecated
d.        volatile fields cause a write to be issued after calling update even if the m_desired equals to m_mirrored
e.        The field name of uvm_config_db can contain wildcards and they are not interpreted as glob/regex.
f.        +uvm_set_default_sequence to set the default sequence
GMT+8, 2025-9-16 06:04 , Processed in 0.013009 second(s), 3 queries , Gzip On, Redis On.
