查看: 9701|回复: 10
How to isolate substrate noise in mixed signal chip
发表于 2007-7-4 21:46:00 | 显示全部楼层 |阅读模式
Dear all,
In mixed signal chip, the huge digital block and I/O buffer noise will affect analog circuit performance through substrate,if put the analog block above Deep Nwell will reduce the effect,but some device PNP,Native Transistor are not allowed above Deep Nwell;so I want to put the digital block and I/O circuit above Deep Nwel,but I worry about I/O circuit above Deep Nwell will lead to ESD issue,anyone can give me some suggestion?
Thanks
Jim
发表于 2007-7-5 04:42:16 | 显示全部楼层
Hi,
I am quite intersted in this topic too, as what I know, the deep nwell is a good way to isolate noise from digitial part, usually what peoples concern is that a extra mask needed, and it costs money of course. one alternative is to place a ring around analog region, it helps.
Here I don't understand is, why native device or pnp can't be inside deep nwell? any reason?
发表于 2007-10-7 16:56:39 | 显示全部楼层
Now most DNW process is standard. No more money needed.
发表于 2007-10-8 10:22:40 | 显示全部楼层
THANKS
发表于 2010-6-3 13:13:32 | 显示全部楼层
native device can, PNP cannot
发表于 2012-8-12 16:15:31 | 显示全部楼层
tks for your knowledge
发表于 2012-8-19 12:54:33 | 显示全部楼层
A new JSSC paper(2012) deals with this problem
abbr_82ba620f270a5038020401566afe4e15.pdf
1.89 MB, 下载次数: 202 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-8-20 09:06:23 | 显示全部楼层
NTN layer,  spacing.....the tradeoff of noise performance is just area
发表于 2014-11-20 12:24:39 | 显示全部楼层
Thx for your knowledge!
发表于 2016-12-19 21:21:13 | 显示全部楼层
102411
GMT+8, 2025-12-25 10:25 , Processed in 0.021522 second(s), 4 queries , Gzip On, Redis On.
