楼主: ericl1105
ADE_Spectre_SpectreRF_Lab library(60MB)
发表于 2009-6-17 12:50:35 | 显示全部楼层
发表于 2009-6-17 13:28:12 | 显示全部楼层
thanks
发表于 2009-9-9 10:25:16 | 显示全部楼层
ok
发表于 2009-9-9 10:26:46 | 显示全部楼层
ok
ADE_Spectre_SpectreRF_Lab library(60MB after extracting RAR))
including 13 parts.
This materials(training & cadence files) may be helpful for your simulation works in Cadence(5xxx)
Content :
***ADE:
/artist_states
/test/
CORNERS
/dchecklab
/InhConn
/MDLlab
/MDLlabtest
/mmatch
/Models
/OCEAN
/PES
/PSKILL
/rcx_ade
/results
/simulation
/solutions
/spectre500
/Stab
/testscriptbuild
/training
/training:
Ampv
Control
Controlv
Diodev
foldedCascode
inv
invv
LF
My_nor2
Mydiode
Nand2
Nand2v
PD
peakDetectv
peakTestv
PLL
RSFF
Schmitt
Supply
Test
VCO
Vinv
***SpectreRF:
/artist_states
/test
/Models
/pllLib
/simulation
/solns
/training
/training:
Adder
ATF26100opt
BBA
EF_example
EF_example2
EF_PA_istg
EF_PA_ostg
Ef_test
Ind_example
Lna
Lnasimple
Mixer2
Mline
Multiplier
Ne600p
Ne600
nportTest
o-ne600
oscHartley
PA_istg
PA_ostg
Pi_over4)dqpsk
Port
portAdapter
schemModel
spData
t_inverter
tab_sp_test
tab_sp_test2
tline3
tline3oscRFlmg
twa3b
发表于 2009-9-9 10:28:06 | 显示全部楼层
ok
including 13 parts.
Content :
***ADE:
/artist_states
/test/
CORNERS
/dchecklab
/InhConn
/MDLlab
/MDLlabtest
/mmatch
/Models
/OCEAN
/PES
/PSKILL
/rcx_ade
/results
/simulation
/solutions
/spectre500
/Stab
/testscriptbuild
/training
/training:
Ampv
Control
Controlv
Diodev
foldedCascode
inv
invv
LF
My_nor2
Mydiode
Nand2
Nand2v
PD
peakDetectv
peakTestv
PLL
RSFF
Schmitt
Supply
Test
VCO
Vinv
***SpectreRF:
/artist_states
/test
/Models
/pllLib
/simulation
/solns
/training
/training:
Adder
ATF26100opt
BBA
EF_example
EF_example2
EF_PA_istg
EF_PA_ostg
Ef_test
Ind_example
Lna
Lnasimple
Mixer2
Mline
Multiplier
Ne600p
Ne600
nportTest
o-ne600
oscHartley
PA_istg
PA_ostg
Pi_over4)dqpsk
Port
portAdapter
schemModel
spData
t_inverter
tab_sp_test
tab_sp_test2
tline3
tline3oscRFlmg
twa3b
发表于 2009-9-9 10:30:10 | 显示全部楼层
ok
including 13 parts.
Content :
***ADE:
/artist_states
/test/
CORNERS
/dchecklab
/InhConn
/MDLlab
/MDLlabtest
/mmatch
/Models
/OCEAN
/PES
/PSKILL
/rcx_ade
/results
/simulation
/solutions
/spectre500
/Stab
/testscriptbuild
/training
/training:
Ampv
Control
Controlv
Diodev
foldedCascode
inv
invv
LF
My_nor2
Mydiode
Nand2
Nand2v
PD
peakDetectv
peakTestv
PLL
RSFF
Schmitt
Supply
Test
VCO
Vinv
***SpectreRF:
/artist_states
/test
/Models
/pllLib
/simulation
/solns
/training
/training:
Adder
ATF26100opt
BBA
EF_example
EF_example2
EF_PA_istg
EF_PA_ostg
Ef_test
Ind_example
Lna
Lnasimple
Mixer2
Mline
Multiplier
Ne600p
Ne600
nportTest
o-ne600
oscHartley
PA_istg
PA_ostg
Pi_over4)dqpsk
Port
portAdapter
schemModel
spData
t_inverter
tab_sp_test
tab_sp_test2
tline3
tline3oscRFlmg
twa3b
发表于 2010-5-3 12:24:42 | 显示全部楼层
怎么用呢
发表于 2010-5-17 10:04:05 | 显示全部楼层
谢谢楼主分享~~
发表于 2010-10-9 00:13:37 | 显示全部楼层
回复 1# ericl1105
    thxxxxxxxxxxxxxxxxx
发表于 2010-10-9 08:26:48 | 显示全部楼层
回复 41# liazhen
    thxxxxxxxxxxxxxxxxxx.
GMT+8, 2025-12-29 02:17 , Processed in 0.025936 second(s), 5 queries , Gzip On, Redis On.
