查看: 2504|回复: 3
[求助] nanosim 求助!
发表于 2017-11-13 18:53:18 | 显示全部楼层 |阅读模式
各位好,刚开始学习nanosim+vcs ,安装了nanosim 2008.03 sp1
bashrc设置:
export MANPATH=/opt/synopsys/NS_vA-2008.03-SP1/doc/ns/manMANPATH
export PATH=/opt/synopsys/NS_vA-2008.03-SP1/amd64/amd64/ns/execPATH
export NANOSIM_64=1
export EPIC_HOME=/opt/synopsys/NS_vA-2008.03-SP1
运行 nsgui,可以打开gui界面,
跑 example的lab1, adder.vec adder.spi
simulation报错:
/opt/synopsys/NS_vA-2008.03-SP1/amd64/amd64/ns/exec/nanosim: error while loading shared libraries: libModel.so: cannot open shared object file: No such file or directory
求助大家帮助解决,万分感谢!刚开始学习nanosim+vcs,困难重重!
发表于 2017-11-13 19:36:57 | 显示全部楼层
这是analog板块,你这个应该发去数字板块吧
 楼主| 发表于 2017-11-16 09:16:02 | 显示全部楼层
EDA里面已经有libModel.so了,我locate libModel.so,有找到下面几个:
/opt/synopsys/NS_B-2008.09-SP2/amd64/amd64/ns/exec/libModel.so
/opt/synopsys/NS_B-2008.09-SP2/amd64/amd64/ns/lib/libModel.so
/opt/synopsys/NS_B-2008.09-SP2/doc/ns/examples/nanosim/ADFMI/sin_hwi/libModel.so
/opt/synopsys/NS_B-2008.09-SP2/linux/linux/ns/lib/libModel.so
我把这几个lib路径加到LD_LIBRARY_PATH里面,问题还是存在。
export LD_LIBRARY_PATH=(/usr/local/lib:/lib:/usr/lib:/usr/dt/lib:/usr/openwin/lib:/opt/synopsys/NS_B-2008.09-SP2/amd64/amd64/ns/exec:/opt/synopsys/NS_B-2008.09-SP2/amd64/amd64/ns/lib:/opt/synopsys/NS_B-2008.09-SP2/doc/ns/examples/nanosim/ADFMI/sin_hwi:/opt/synopsys/NS_B-2008.09-SP2/linux/linux/ns/lib:/opt/synopsys/NS_B-2008.09-SP2)
问题还是没有解决
还是报错:
/opt/synopsys/NS_B-2008.09-SP2/amd64/amd64/ns/exec/nanosim: error while loading shared libraries: libModel.so: cannot open shared object file: No such file or directory
我用的是bashrc,请问你是怎么设置的?可以把你的bashrc或者cshrc分享一下?
发表于 2017-12-18 13:51:01 | 显示全部楼层
thanks a lot.
GMT+8, 2025-12-29 03:05 , Processed in 0.016744 second(s), 4 queries , Gzip On, Redis On.
