查看: 3417|回复: 6
[资料] keysight slides
发表于 2017-10-3 21:50:02 | 显示全部楼层 |阅读模式
1.BackToBasics_Keysight_EEsof_v2.pdf (1.24 MB , 下载次数: 42 )
2.RF_simulation_Basics-v2.pdf (3.05 MB , 下载次数: 48 )
 楼主| 发表于 2017-10-3 21:52:43 | 显示全部楼层
Internet of Things_IoTEnglish
1.Battery Drain Analysis for Low Power IoT Devices.pdf (2.13 MB , 下载次数: 11 )
2.Five Tips for Optimizing Battery Drain on IoT Devices.pdf (1.46 MB , 下载次数: 9 )
3.IoT With Great Power Comes Great Challenges.pdf (3.76 MB , 下载次数: 9 )
4.Maximizing Battery Life of IoT Smart Devices with Keysight Solutions.pdf (720.8 KB , 下载次数: 8 )
5.Measuring Battery Life on Battery-Powered Medical Devices.pdf (645.51 KB , 下载次数: 7 )
6.Solving Test Challenges for Enabled Consumer Electronics Devices.pdf (2.31 MB , 下载次数: 7 )
7.Test Challenges and Keysight Solutions for IoT Smart Devices.pdf (2.03 MB , 下载次数: 9 )
Chinese:
1.Battery Drain Analysis for Low Power IoT Devices.pdf (918.55 KB , 下载次数: 7 )
2.Five Tips for Optimizing Battery Drain on IoT Devices.pdf (1.93 MB , 下载次数: 8 )
3.IoT With Great Power Comes Great Challenges.pdf (2.62 MB , 下载次数: 6 )
4.Maximizing Battery Life of IoT Smart Devices with Keysight Solutions.pdf (857.53 KB , 下载次数: 6 )
5.Measuring Battery Life on Battery-Powered Medical Devices.pdf (541.34 KB , 下载次数: 6 )
6.Solving Test Challenges for Enabled Consumer Electronics Devices.pdf (1.59 MB , 下载次数: 6 )
7.Test Challenges and Keysight Solutions for IoT Smart Devices.pdf (1.22 MB , 下载次数: 7 )
 楼主| 发表于 2017-10-3 21:55:06 | 显示全部楼层
Arbitrary Waveform Generators 1.Creating a Differential Signal with a Waveform Generator.pdf (1.27 MB , 下载次数: 11 )
2.Flexible Digital Modulation Solution.pdf (2.93 MB , 下载次数: 7 )
4.Simplify the Generation of High-Quality IQ Signals.pdf (303.25 KB , 下载次数: 10 )
5.Trueform Waveform Generation Technology.pdf (959.4 KB , 下载次数: 8 )
6.Using a Waveform Generator to Generate a PRBS Signal.pdf (1.25 MB , 下载次数: 7 )
Chinese:
2.Flexible Digital Modulation Solution.pdf (1.62 MB , 下载次数: 6 )
5.Trueform Waveform Generation Technology.pdf (1.67 MB , 下载次数: 5 )
6.Using a Waveform Generator to Generate a PRBS Signal.pdf (577.97 KB , 下载次数: 7 )
 楼主| 发表于 2017-10-3 21:58:49 | 显示全部楼层
Oscilloscopes 1.7 Hints That Every Engineer Should Know.pdf (3.32 MB , 下载次数: 8 )
2.Choosing the Best Passive and Active Oscilloscope Probes.pdf (3.37 MB , 下载次数: 8 )
4.Eight Hints for Better Scope Probing.pdf (5.53 MB , 下载次数: 8 )
5.Evaluating Oscilloscope Bandwidths for Your Application.pdf (1.77 MB , 下载次数: 9 )
6.Evaluating Oscilloscope Fundamendals.pdf (1.67 MB , 下载次数: 10 )
7.Evaluating Oscilloscope Signal Integrity.pdf (2.5 MB , 下载次数: 8 )
11.How to Select Your Next Oscilloscope.pdf (9.35 MB , 下载次数: 11 )
12.Oscilloscope Memory Architectures.pdf (3.69 MB , 下载次数: 7 )
15.What is the difference between an equivalent time and a real-time oscilloscope.pdf (1.93 MB , 下载次数: 9 )
16.When is it time to transition to a higher bandwidth oscilloscope.pdf (1.64 MB , 下载次数: 8 )
Chinese:
1.7 Hints That Every Engineer Should Know.pdf (1.26 MB , 下载次数: 7 )
2.Choosing the Best Passive and Active Oscilloscope Probes.pdf (850.66 KB , 下载次数: 8 )
4.Eight Hints for Better Scope Probing.pdf (1.5 MB , 下载次数: 7 )
5.Evaluating Oscilloscope Bandwidths for Your Application.pdf (909.83 KB , 下载次数: 7 )
6.Evaluating Oscilloscope Fundamendals.pdf (1.51 MB , 下载次数: 8 )
7.Evaluating Oscilloscope Signal Integrity.pdf (3.9 MB , 下载次数: 9 )
12.Oscilloscope Memory Architectures.pdf (1013.38 KB , 下载次数: 8 )
15.What is the difference between an equivalent time and a real-time oscilloscope.pdf (1.53 MB , 下载次数: 8 )
发表于 2017-10-8 20:03:02 | 显示全部楼层
have  a look!
发表于 2018-7-18 16:19:47 | 显示全部楼层
thank
发表于 2020-11-2 19:19:26 | 显示全部楼层
不好的资料
GMT+8, 2025-12-30 03:35 , Processed in 0.019354 second(s), 4 queries , Gzip On, Redis On.
