查看: 2387|回复: 1
[求助] check_timing -no_clock -multiple_clock in primeTime errors
发表于 2017-9-21 07:10:17 | 显示全部楼层 |阅读模式
I am using PrimeTime 2016.12
and tried to run this:
Error: unknown option '-no_clock' (CMD-010)
Error: unknown option '-multiple_clock' (CMD-010)
looked that the man page do not have the options either:
check_timing
NAME
       check_timing
              Reports possible timing problems in the design.
SYNTAX
       string check_timing
              [-verbose]
              [-significant_digits digits]
              [-ms_min_separation delta]
              [-override_defaults check_list]
              [-include check_list]
              [-exclude check_list]
do we have anything perform the same?
发表于 2017-9-21 13:49:28 | 显示全部楼层
Only check these two?try:
check_timing -override_defaults "no_clock data_check_multiple_clock"
I think you should check the variable timing_check_defaults first.
GMT+8, 2025-9-15 17:34 , Processed in 0.133339 second(s), 4 queries , Gzip On, Redis On.
