查看: 2406|回复: 2
[求助] Synopsys VCS 仿真
发表于 2017-9-21 04:12:47 | 显示全部楼层 |阅读模式
各位大神,小弟现在在用VCS进行电路仿真, 在具体实践中遇到了一些问题希望求助大家。 我现在用VCS仿真电路,写了一个toplevel 文件和一个testbench。 我目前可以用DVE, 观察到testbench和toplevel里nodes的波形。 不过我尝试用$fwrite 和$monitor指令获得各个node的值,却只能得到testbench里输入和输出node的值,请问有没有办法可以输出toplevel里nodes的值呢?
谢谢大家!
发表于 2017-9-21 15:28:36 | 显示全部楼层
試試明確指定要dump出來的信號名。
比如
always @ (posedge clk) begin
if (dump_enable) //you want record the value in the specified simulation time
    $fwrite(wid, "signal1 = %h\n", tb.toplevel.signal1);
end
 楼主| 发表于 2017-9-22 02:32:11 | 显示全部楼层
回复 2# wide_road
   不好意思,看的不是很明白。可以舉個例子嗎?假設我的toplevel是這個:
`timescale 1ns/10ps
module c103 ( N1, N2, N3, N4, N5, N6, N11 );
  input N1, N2, N3, N4, N5, N6;
  output N11;
  wire   n3, n4;
  OA22X1_RVT U4 ( .A1(n3), .A2(N3), .A3(n4), .A4(N6), .Y(N11) );
  AND2X1_RVT U5 ( .A1(N5), .A2(N4), .Y(n4) );
  AND2X1_RVT U6 ( .A1(N2), .A2(N1), .Y(n3) );
endmodule
testbench是這個:
`include "saed32nm.v"
`timescale 1ns/10ps
module c103_tb();
  reg N1, N2, N3, N4, N5, N6;
  wire N11;
integer statusI,in, fileid;
c103 a ( N1, N2, N3, N4, N5, N6, N11 );
initial
$vcdpluson;//Record all signal value changes;
initial begin
in = $fopen("data6.txt","r");
fileid = $fopen("c103.txt","w");
repeat (100) begin
#5 statusI = $fscanf(in,"%h %h\n %h\n %h\n %h\n %h\n",N1, N2, N3, N4, N5, N6);
$display("|n3|n4|\n");
$monitor ("%t ",$time, c103.n3, c103.n4);
$strobe ("%t ",$time, c103.n3, c103.n4);
// $fwrite(fileid, "%t ",$time, N1, N2, N3, N4, N5, N6, "\t", N11,"\n" c103.n3, c103.n4);
end
$fclose(in);
$fclose(fileid);
#300  $finish;
end
endmodule
我想觀測node n3和n4.
目前我用的指令是:vcs c103_gate.v c103_benchmark.v -sverilog -debug_all +vcd+vcdpluson
請問應該怎麼改呢?
謝謝。
GMT+8, 2025-12-29 20:35 , Processed in 0.013991 second(s), 4 queries , Gzip On, Redis On.
