查看: 5275|回复: 2
[求助] vcs core dump
发表于 2017-9-1 15:46:58 | 显示全部楼层 |阅读模式
用vcs仿真的时候是不是出现如下信息:Warning: Incorrect SIGSEGV signal handler override detected.
                Signal handler at address 0x7f07fb32e7a0 seems to be overriding VCS signal handler
                without setting SA_SIGINFO flag in the handler. Some VCS functionality will be lost.
Info: Most likely PLI or third party library seems to be overriding VCS SIGSEGV Signal Handler.
                Please check PLI or third party library at address 0x7f07fb32e7a0 .
Note: Execution of simv exited with code 255
CPU time: 5.700 seconds to compile + 1.639 seconds to elab + .448 seconds to link + 95.678 seconds in simulation
make: *** [vcs] Error 255
vcs用的是2014版本,verdi是2016版本,是不是verdi版本不兼容引起的问题啊
发表于 2017-9-1 23:44:49 | 显示全部楼层
verdi 2016 支援 vcs 1412 1509 1606 建議使用verdi1403 vcs1403 最穩當
 楼主| 发表于 2017-9-2 13:47:56 | 显示全部楼层
回复 2# timtim016801
谢谢啦,我试一下
GMT+8, 2025-12-23 12:35 , Processed in 0.016112 second(s), 3 queries , Gzip On, Redis On.
