查看: 3004|回复: 1
[讨论] sva断言log信息分析
发表于 2017-7-6 10:44:34 | 显示全部楼层 |阅读模式
各位,   一个简单同步低有效复位D触发器
模块简略代码:
   input a,rst,clk
   output q
   always @(posedge clk)begin
      if(!rst)
         q <= 1'b0;
      else
          q <= a;
   end
sva_src.sv:
    sequence s1;
      rst;
    endsequence
property p1;
  @(posedge clk) s1 |->
      (a, $display("P1 assert a = 1 is success\n"));
endproperty
a1: assert property(p1);
testbench.sv:
   initial begin
     clk = 1'b1;
     rst = 1'b 0;
     a = 1'b0;
     #6 rst = 1'b1;
   end
   always #1 clk = ~clk;
       a = ~a;
   initial begin
     #100 $stop;
   end
执行以后打出如下log:
"sva_src.sv", 29: testbench.st.ss.a1:assert at 8ns failed at 8ns
       Offending 'a'
P1 asserty a = 1 is success
"sva_src.sv", 29: testbench.st.ss.a1:assert at 12ns failed at 8ns
       Offending 'a'
想问一下,从波形上看,以及打印的success信息,明明已经成功了的,红色字体的log信息中的failed的什么意思?
Best Regards!
发表于 2017-7-11 14:54:10 | 显示全部楼层
波形呢?
GMT+8, 2025-9-14 13:53 , Processed in 0.011412 second(s), 3 queries , Gzip On, Redis On.
