楼主: xiaowang8900
[求助] 关于create_generate_clock
 楼主| 发表于 2017-6-28 21:58:34 | 显示全部楼层
回复 6# masaka_xlw
   不过ICG应该是可以穿过去的吧?
发表于 2017-6-29 08:38:04 | 显示全部楼层
回复 9# xiaowang8900
   就像你回复我上个条目说的那样, set_propagate_clock 在post layout才用。那么在ideal network阶段,如果你想要模拟network latency,那只能一段段的标上。我试了下,如果自己标了network latency, 又设了propagate, 标了的值就无效了。两者互斥,很合理。     毕竟你已经设了 不允许propagate.
    By default, the tool assumes ideal clocking, which means clocks have a specified network latency (from the set_clock_latency command) or zero network latency by default. Propagated clock network latency (from the set_propagated_clock command) is normally used after layout and final clock tree generation.
     Specifying the ideal clock network latency provides an estimate of the clock tree delay for before layout.
 楼主| 发表于 2017-6-30 19:45:38 | 显示全部楼层
回复 12# sdlyyuxi
   恩,谢谢啦
发表于 2017-7-1 01:49:54 | 显示全部楼层
回复 10# xiaowang8900
正常情况下ICG在任何tech process下都是能被时钟穿过的。感觉有点像时钟树在前仿和后仿中,工具如何解释的问题。
一般后仿直接就propagate了,延迟参数直接从后端过来。前仿真往往都是ideal的,除非强行force delay。。
GMT+8, 2025-12-24 17:12 , Processed in 0.021250 second(s), 3 queries , Gzip On, Redis On.
