查看: 1581|回复: 3
still could not run virtuoso, please help
发表于 2017-6-18 14:04:42 | 显示全部楼层 |阅读模式
Here are the license daemon log:
23:03:39 (lmgrd) World Wide Web:  http://www.macrovision.com
23:03:39 (lmgrd) License file(s): /home/tools/cadence/license/license.lic
23:03:39 (lmgrd) lmgrd tcp-port 5288
23:03:39 (lmgrd) Starting vendor daemons ...
23:03:39 (lmgrd) Started cdslmd (internet tcp_port 53099 pid 27329)
23:03:39 (cdslmd) FLEXnet Licensing version v10.8.0.7 build 26147
23:03:39 (cdslmd) Invalid license key (inconsistent authentication code)
23:03:39 (cdslmd)       ==>FEATURE 100 cdslmd 16.6 permanent 999 SIGN2="1822 7552 EA76 8BF3 FA67 \
        9903 8E00 EF59 1556 DE72 05C3 5066 9CFE 50D7 AA0B 01A7 141A \
        5471 13AE 6DED B3D1 B021 A929 4D94 6F19 7CDF 007F 998A BF02 \
        9B06"
23:03:39 (cdslmd)       ==>FEATURE 111 cdslmd 16.6 permanent 999 SIGN2="11A0 4310 0623 C1C9 405D \
        467D CA86 9105 7A83 4822 CCD0 C2A1 BAD8 B72B 7027 1AB6 B1E3 \
        AC02 57AA 7976 DC22 55D5 D6A9 6AC9 270D 51AC FD5F 5B3D 68ED \
        F3EA"
发表于 2017-6-20 10:00:16 | 显示全部楼层
license 不对
发表于 2017-6-21 15:58:22 | 显示全部楼层
licensing issue. check machine id..
 楼主| 发表于 2017-6-23 08:25:04 | 显示全部楼层
回复 3# eng9135
thank you folks for replying
Could you help by specify what to check? I tried a lot of license files and carefully apply the hostid of my
server,
GMT+8, 2025-10-30 04:15 , Processed in 0.017317 second(s), 4 queries , Gzip On, Redis On.
