查看: 21960|回复: 16
[求助] PSS仿真中使用shooting和harmonic balance方法的区别
发表于 2017-5-28 16:43:01 | 显示全部楼层 |阅读模式
我是想进行DCO频率响应的仿真,使用PSS+PSTB仿真,但是使用shooting和harmonic balance方法的结果差异很大,请问各位知道这两种方法都适用于什么情况吗?忘各路大神不吝赐教~ pstb.jpg PSTB设置 pss.jpg pss设置 HB.jpg HB LOOP GAIN shooting.jpg shooting LOOP GAIN
 楼主| 发表于 2017-5-31 09:33:11 | 显示全部楼层
走过路过的大神~求指点~
发表于 2017-6-10 17:52:25 | 显示全部楼层
一个是基于时域分析,一个是基于频域分析,可以看下这个帖子
http://bbs.eetop.cn/thread-556267-1-1.html
发表于 2019-2-20 09:22:43 | 显示全部楼层
回复 3# tf001
    谢谢
发表于 2019-2-20 13:40:37 | 显示全部楼层
xuexile
发表于 2020-4-2 11:11:39 | 显示全部楼层
围观学习
发表于 2020-8-22 10:19:58 | 显示全部楼层
围观学习
发表于 2020-8-22 11:24:58 | 显示全部楼层
参考:Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooting Newton Engine? (https://community.cadence.com/ca ... oting-newton-engine)
Use harmonic balance for:
    High dynamic range, weakly-nonlinear systems
        RF front-ends (LNA, Mixer)
        IQ modulators
    Mildly nonlinear oscillators with resonators, such as
        LC oscillators
        Crystal oscillators
        Negative-gain oscillators
    Circuits with distributed components
        Transmission lines
        S-parameter models
Use shooting Newton for:
    Circuits where input signals have sharp transitions
    Strongly nonlinear circuits
        Frequency dividers
        Strongly-nonlinear resonatorless oscillators, such as
            Ring oscillators,
            Relaxation oscillators,
            Oscillators containing digital control components,
            Oscillators with dividers.
简而言之就是偏线性、正弦的用HB,偏logic、方波的用shooting。
回复 支持 7 反对 0
发表于 2020-12-17 15:42:14 | 显示全部楼层
远上寒杉 发表于 2020-8-22 11:24
参考:Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooting Newton Engine? ( ...
请教一下,电路里面有frequency divider by 2, 也有s parameter model, 该用pss harmonic balance 还是shooting呢
发表于 2021-1-4 10:17:03 | 显示全部楼层
shaohaijun 发表于 2020-12-17 15:42
请教一下,电路里面有frequency divider by 2, 也有s parameter model, 该用pss harmonic balance 还是sh ...
shooting的特点是收敛性好,hb的特点是快,所以不适合用hb的时候就用shooting吧。
GMT+8, 2025-12-18 22:27 , Processed in 0.022679 second(s), 4 queries , Gzip On, Redis On.
