楼主: slq402
[求助] PSS仿真中使用shooting和harmonic balance方法的区别
发表于 2021-9-8 13:59:58 | 显示全部楼层
远上寒杉 发表于 2020-8-22 11:24
参考:Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooting Newton Engine? ( ...
就很有用
发表于 2022-6-27 17:15:42 | 显示全部楼层
根据楼里大神总结:
参考:Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooting Newton Engine? (https://community.cadence.com/ca ... oting-newton-engine)
Use harmonic balance for:
    High dynamic range, weakly-nonlinear systems
        RF front-ends (LNA, Mixer)
        IQ modulators
    Mildly nonlinear oscillators with resonators, such as
        LC oscillators
        Crystal oscillators
        Negative-gain oscillators
    Circuits with distributed components
        Transmission lines
        S-parameter models
Use shooting Newton for:
    Circuits where input signals have sharp transitions
    Strongly nonlinear circuits
        Frequency dividers
        Strongly-nonlinear resonatorless oscillators, such as
            Ring oscillators,
            Relaxation oscillators,
            Oscillators containing digital control components,
            Oscillators with dividers.
简而言之就是偏线性、正弦的用HB,偏logic、方波的用shooting。
shooting的特点是收敛性好,hb的特点是快,所以不适合用hb的时候就用shooting。
回复 支持 4 反对 0
发表于 2022-7-20 09:38:18 | 显示全部楼层
JennniferHo 发表于 2022-6-27 17:15
根据楼里大神总结:
参考:Tip of the Week: When should I use the pss/qpss Harmonic Balance vs. Shooti ...
你好想请教一下,就是晶振电路,但是想看晶振整形后的方波的信号,这个时候是否选shooting更合适呢?
如果是想看晶振的expin的信号(正弦波)就选HB更合适?
发表于 2022-10-26 16:01:02 | 显示全部楼层
学到了,谢谢大神
回复 支持 0 反对 1
发表于 2024-11-19 17:02:54 | 显示全部楼层
mark_shooting and HB
发表于 2024-11-28 10:34:16 | 显示全部楼层
MARK pss shooting&harmonic balance
发表于 2024-11-28 10:35:38 | 显示全部楼层
mmmmmmm
GMT+8, 2025-12-19 08:37 , Processed in 0.015329 second(s), 3 queries , Gzip On, Redis On.
